service engine soon light on lower right dash
Old Oct 10, 2001 | 08:16 PM
white98se
I had this warning "service engine soon light" come on while driving to work. I went to the dealer, they indicated it's a sensative emission system. They said it happens alot. (They didn't have it on the diagnosis). Runs fine, 67K miles.
Just did platinum plugs,air filter.
Anyone else have this happen?
thanks.
Old Oct 10, 2001 | 08:35 PM
Ravq's Avatar
You can pull the DTCs from
http://vbxmaxima.8m.com/ecu.html
And translate the codes using:
http://vbxmaxima.8m.com/ecudecoder.html
Old Oct 10, 2001 | 08:37 PM
Ravq's Avatar
You can also refer to this thread for more info on the Diagnostic Trouble Codes.
http://forums.maxima.org/showthread.php?threadid=45274
Old Oct 11, 2001 | 05:16 AM
mzmtg's Avatar
Minister of Silly Walks
Just to add, never go to that dealer again, apparently, they are idiots...
Old Oct 11, 2001 | 07:18 PM
white98se
did the diagnostic
Used the website from vbxmaxima. Instructions were perfect
Thanks alot.
I got a code: 55. 5 long 5 short. Double checked it several times.
Diagonsis: No Failure Recorded/Detected
I'm not sure what that means.
Thanks for any advise, before calling the dealer near home (not the ones by work).
Old Oct 12, 2001 | 01:56 AM
black019's Avatar
<--- recomends the above advice
Old Oct 12, 2001 | 08:15 AM
BRIGBOY's Avatar
Re: service engine soon light on lower right dash
Yep that where ya usually get it.
Old Oct 12, 2001 | 08:51 AM
dwapenyi's Avatar
Re: did the diagnostic
0505 is all good. It means exactly waht you siad, nothing's wrong. Just reset your ECU and Fuhgetaboutit!
DW
Thanks alot.
Old Oct 12, 2001 | 08:52 AM
dwapenyi's Avatar
Re: Re: service engine soon light on lower right dash
Ha!
DW
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
