Adjusting Camber??? Help!!..
Old Nov 1, 2000 | 03:03 PM
ZuMBLe's Avatar
Okay, my car has been acting really weird lately. It follows grooves on the road and feels really "jumpy". So while I was changing oil today I decided to look under the car. No damage to anything that I could see. I pulled out the report sheet from my last allignment and looked at it. I have 0 Camber on my left front wheel. -0.2 on the right front. I know I shouldn't have 0 camber on my front wheels. So my question is. Can I correct this myself? Will taking off my strut bolts and pushing the strut towards the middle of the car and tightening help? For you suspension experts. Where is my report. Any input would be great..
Left Front:
Caster: 2.7
Camber: 0.0
Toe: 0.10
SAI: 13.1
Included Angle: 13.3
Right Front:
Caster: 3.0
Camber: -0.2
Toe: 0.10
SAI: 7.7
Included Angle: 7.2
Whats SAI?? Why are the two #s so far off??
ZuM
Old Nov 1, 2000 | 04:46 PM
seven's Avatar
i don't know if this helps but...
ingalls does make a camber kit for the maxima front that's only like 20 bucks. it gives you +/- 1.0 camber...it looks pretty straightforward. replace a factory bolt thingy with theirs and i'm guessing you can adjust the amount of camber you want from their.
Old Nov 1, 2000 | 05:13 PM
ZuMBLe's Avatar
Re: i don't know if this helps but...
Ingalls? More info please. You're saying I have to replace the caps of my strut? The thing that has the three bolts? Ouch.. If I were to do that.. I'd redo my suspension.. But more info please.. =)
ZuM
Old Nov 1, 2000 | 05:30 PM
Kato
I don't know much about the camber bolts, but here's the link to their site. There should be some pretty good info.
Ingalls Engineering
Old Nov 1, 2000 | 05:58 PM
demian's Avatar
Stillen has camber kit bolts as well. It runs about $30-40. Just have them installed (they replace stock strut bolts) and then get your car aligned. You can adjust +/- 1.0 degrees. When you call Stillen they will try and get you to buy camber plates that run a lot more, I think around $300. Don't go for it. Just get the camber kit.
Old Nov 1, 2000 | 06:10 PM
seven's Avatar
lightningmotorsports.com: $23 :)
Old Nov 1, 2000 | 06:14 PM
got rice?'s Avatar
you can try the ghetto-rigged setup.. lol
in Grassroots Motorsports, they had a Mustang where they drilled out the upper strut bolts to allow for camber adjustment just by moving the strut unit inward/outward... but most people aren't will to drill ..hehe.. get the camber plates for a cleaner setup. but, you'll have to remove the springs/struts to install them.. 3-4 hour job.
Old Nov 1, 2000 | 06:18 PM
seven's Avatar
i think camber plates give you ...
a harsher ride because of the metal to metal contact, plus they're too damn much. i would get the camber plates if i had coilovers though, but for lowering springs i think camber bolts are the sensible alternative.
Old Nov 1, 2000 | 06:19 PM
seven's Avatar
BTW these bolt near the bottom of the strut assembly not the strut tower bolts on top.
Old Nov 1, 2000 | 07:39 PM
ZuMBLe's Avatar
Wow, I just checked it out. Looks pretty promising. And for 23 dollars? My major concern would be the camber settings changing. Like the bolt rotating. Anyone use these before?
ZuM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
