Attn: Auto Body Specialists
Old Oct 16, 2001 | 11:09 PM
ImportMax
I have sanded down my bumper very well. I primed it and sanded it again. It is very smooth now. I an goin to put on about 2-3 coats of color coat and same for clear coat. The last time I did this my front bumper did not look so shinny and did not have much depth. How can I make sure it will look much shinnier this time? Any tips and.or suggestions will be appreciated!
Old Oct 16, 2001 | 11:13 PM
1MAX2NV's Avatar
Re: Attn: Auto Body Specialists
I don't think they use color coat and then clear coat on bumpers. They do on metal body parts, but on bumpers it's a different process.
Old Oct 17, 2001 | 05:31 AM
njmaxseltd's Avatar
You need a flex agent in the primer for bumpers. I think Sherman Williams sells the primer specially made for bumpers. As far as your shine goes, you need to have a really good gun. Make sure you spray very fine mist and do 2 or 3 coats. Clear you only need 2 coats of.
And yes, it's base coat, clear coat. If you still don't like the shine, get some good rubbing polish and a machine, but be carefull with the machine, you'll go right through the paint on the corners. Just buff it up to a nice shine.
Old Oct 17, 2001 | 07:03 AM
1MAX2NV's Avatar
Oops...i was wrong.
Old Oct 17, 2001 | 08:38 AM
MaximaRacer's Avatar
Where can I get the Sherman Williams primer?
Old Oct 17, 2001 | 08:46 AM
njmaxseltd's Avatar
Automotive/body shop supply house. Check your yellow pages or call a body shop and ask them where they buy paint from. I think Standox is another mfg. of primers and paint for your application.
Old Oct 17, 2001 | 09:07 AM
DanNY's Avatar
Ad·min·is·tra·tor
also it's the technique..if you're too far away the paint will dry b4 it hits the panel..so you'll get a dull look.
also make sure the paint "flashes" before you slap another coat. runs are a no no.
for the clear make sure it's not too humid out.
REDinLV
Aug 15, 2024 12:30 AM
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
