Guys Any Of U Install your Own Springs in the Max or have it done?
Old Nov 1, 2000 | 04:18 PM
PIONEER's Avatar
My Springs should be coming in shortly and I need to know if I can just go rent a spring compressor and install them myself or should I have someone put them in? Also I got H&R, someone talk to me about camber Plates. They go at the top of the strut tower right? and has a bolt to adjust them? need a little help.
Old Nov 1, 2000 | 04:30 PM
[s3]'s Avatar
Doing it yourself?
Plan on 4 hours of blood sweat and tears...
I've changed springs on Maximas about 6 times, its getting pretty routine. If you are not prone to hard work or haven't done it before, its best to pay someone 100 bucks to suffer for an hour or so.
You can rent spring compressors (manual ones) from Autozone or most car part places. You'll need a socket set, wrenches, and lots of muscle. Yes camber plates go on top and has a bolt to adjust them. Installs pretty easy.
Good luck
Old Nov 1, 2000 | 04:50 PM
PIONEER's Avatar
another question. when springs are installed, which part is up, the closer part of the spring or the part that has more distance? I called a place today, the lady told me $250 to put them in and said it'll take 3 hours. WTF, I think she don't know what she was talking about.
Old Nov 1, 2000 | 05:01 PM
omax's Avatar
I did mine It wasn't that hard but I did have a friend who helped(did most of the work).He had done them before on his Integ.Did take us about three hours though.
Old Nov 1, 2000 | 05:19 PM
Kenneth's Avatar
OG :)
it costed $170, friend paid $135 by saying the rears were shocks vs. "struts" year before me sans an alignment.
no way i'm doing that, so many stuff can go wrong therefore i preferred to watch tv and pay a shop.
plus the guys in the shop said it was a pita to me 3 times.
Old Nov 1, 2000 | 05:30 PM
deathwish's Avatar
Well, I did the coilovers, I didn't think it was that bad. Pep boys rents the compressor for free, you just gotta put the full price on a credit card and then it gets refunded when you bring it back. I think it's worth doing just to get a little closer to your car
Old Nov 1, 2000 | 07:55 PM
brandonj's Avatar
I did it, and I thought it was really straightforward and relatively easy. Check out the Megamax site for instructions. The one thing I forgot that was dumb was to line up the upper strut mount (notch goes to the outside), but it only took 15 minutes to fix once I figured it out. Just make sure you have the right tools and a long breaker bar. I didn't even bleed once, but my legs and back were sore for a couple of days from using all of my strength to loosen some of those nuts. I'd do it again.
Old Nov 1, 2000 | 08:04 PM
Gotrice4's Avatar
Re: Doing it yourself?
[QUOTE]Originally posted by [s3]
[I]Plan on 4 hours of blood sweat and tears...
I wish i could find someone to do it for $100, the few places i called said $200-$400 and bout 4-6 hours and one place said ur gonna have to drop your car at like 8am and we'll see when it gets done, I was like wtf, no one i've ever talked to said it would take this long other than the hicks at these mechanic places. I mean is it really easy to change springs, b/c i don't think that i'm that mechanically inclined but would like to do it if i could...
Old Nov 1, 2000 | 08:20 PM
brandonj's Avatar
Gotrice4
Seriously, it's not a very complicated job. It just requires some time, patience, and brute force. Check out http://integra.vtec.net/geeser/megamax/springs.html and see what you think. It took me 4 hours and I was taking my time to make sure I didn't screw up. If I had to do it again, I bet I could do it in 2 1/2 hours.
Old Nov 1, 2000 | 09:29 PM
PIONEER's Avatar
Damn Chad I was hopeing U'ld read this post, I remember U telling me about the tie wrap method . Anyone here with H&R springs with the cambre plates? I need to know how to set the plates and also how the springs go in. also what do I mark B4 I take the struts out? I haven't looked at the car at all but I know the 3 on top 1 in the center on top, the ball joints, spindle arms gotta come off. shouldn't have to mess with the disk or the bigass center bolt on the Hub right?
Old Nov 2, 2000 | 07:55 AM
maxdrvr847's Avatar
wasnt bad at all, on front take to big bottom bolts off, and then the 3 on the top under the hood, dont take top center bolt off until its in a the spring compressor
Old Nov 2, 2000 | 05:13 PM
PIONEER's Avatar
Good Point. or the **** Was relly gonna go through the roof
Old Nov 2, 2000 | 05:32 PM
Synki's Avatar
Camber Plates? Is it really needed for lowering the Max? I thought if you drop it more then 2" then you need em. BTW any know which springs give the Maxima a BMW look, like how there is about half an inch between tires and wheelwell?
dank4us
34
Jun 10, 2024 03:45 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Economic_Rage
Aug 20, 2015 08:27 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
