glowing needle question
Old Oct 21, 2001 | 11:07 AM
Sexima's Avatar
Do they fit in the Maxima GLE?
is it hard to install?
how will it look WITH the indiglo gauges?
thanks guys
Old Oct 21, 2001 | 03:50 PM
clee130's Avatar
Re: glowing needle question
http://forums.maxima.org/search.php?...der=descending
Yes.
Search would have revealed this answer.
Depends.
You can also send your gauges into http://www.importintelligence.com
Don't know, might look good, might not.
Old Oct 21, 2001 | 04:11 PM
black019's Avatar
do they needles fit i30's? those blue ones are cool...
Old Oct 21, 2001 | 04:18 PM
clee130's Avatar
They are universal. Search would revealed that answer.
Broken record anyone?
Old Oct 21, 2001 | 06:03 PM
SLC I30t's Avatar
Yes the needles from importintelligence work on an I30...
here is a pic of mine, that I just finished.
It's easy to instal just give yourself time to do a good job, the parts are fragile. I also have Chrome rings on my gauges and white faces... so thats what it will look like with those. I don't think they will look good with the Indiglo faces unless you go with the red needles.. it's a contrast thing...BTW I kept my stock bulbs for the background lights, but the whole dash turned a light shade of purple... I like it
Old Oct 21, 2001 | 07:05 PM
thebigsadler's Avatar
what bulbs are behind my gauges? can i change them? how do i get the gauge apart?
just messing with you clee..
you are the best at searching though..
Old Oct 21, 2001 | 08:48 PM
Sexima's Avatar
did u guys order from importintelligence.com
are their service good?
because i have paypal and it's on CHECK banking account
not credit card
they said I need credit card so I don't know what to do
What should I do guys?
I emailed them... I hope they are not like PR CAI people...
Old Oct 21, 2001 | 09:00 PM
SLC I30t's Avatar
They were cool to me... but I have a CC.
Old Oct 21, 2001 | 09:06 PM
SLC I30t's Avatar
Old Oct 22, 2001 | 12:54 PM
jerzeeMax's Avatar
dammit
It SUCKS that Nissan decided to make the needles for '98 and up opaque instead of clear like the '97 and earlier. Man I want those glowing needles. How can I do this without pulling my needles or changing the gauge cluster?
Old Oct 22, 2001 | 01:49 PM
Sexima's Avatar
Re: dammit
i dont think there is a way
just buy the needles man
76.60
for everything
Old Oct 22, 2001 | 02:17 PM
Re: Re: dammit
have import intelligence make you a custom kit like they are for me.. they are gonna sponsor my car.. and put custom logo in each gauge, white on black carbon fiber.. with hyper red needles.. pretty sweet deal.
Old Oct 22, 2001 | 02:19 PM
SLC I30t's Avatar
well you would have to pull the needles off anyhow... just go to the junk yard and get needles off of a 97.
Old Oct 22, 2001 | 03:17 PM
Sexima's Avatar
Re: Re: Re: dammit
what u mean a custom kit?
Old Oct 22, 2001 | 05:50 PM
Re: Re: Re: Re: dammit
yeap.. it'll be pretty hot.. red numbers instead of white.. carbon fiber with white wording.. sweet deal..
Old Oct 23, 2001 | 12:09 AM
mingo's Avatar
do they have them for the 5th gen??
Old Oct 23, 2001 | 12:10 AM
mingo's Avatar
NO search will NOT work for me because i already know the answer
Old Oct 23, 2001 | 07:52 AM
clee130's Avatar
They are universal, therefore, they fit the 5th gen. Which was answered already earlier in this post.
And if you already knew the answer, then why'd you post the question?
Old Oct 23, 2001 | 09:17 AM
magnum's Avatar
it says they are NOT universal, and they will not work with a 98+ Max...
Old Oct 23, 2001 | 09:28 AM
clee130's Avatar
Well... if you want to start getting technical, then yes, they will not work with a 98+ Max because the needles are not opaque. The rings will fit into the needle base, but if you don't have an opaque needle, then the needle won't glow.
But they are "universal" in the fact that the rings should fit into needle, the needle just won't glow. You'll just get a glow under the needle base.
But since you need to take the needles off to install the indiglo needles, you could swap them out for some previous model Max needles.
Old Oct 23, 2001 | 01:23 PM
magnum's Avatar
a ha... well then that is what i am going to do
Old Oct 23, 2001 | 02:19 PM
SLC I30t's Avatar
If you have white face gauges... Let me warn you about putting clear or white gauges on your car... you need to take some glass dye, or a sharpie (permanent marker) and color in the bottom of the needle. It is hard to see that little sucka telling you "that you have just exceeded the speed limit in front of that cop". I'll post that it looks like on Sat when I fix mine.
Old Oct 23, 2001 | 05:28 PM
Sexima's Avatar
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
