How to keep them from peeling off???
Old Oct 22, 2001 | 03:49 PM
Rob'sAE's Avatar
You're Faster, I'm Better
How do you apply the "maxima.org" stickers to your windows in such a way that they do not peel off at 120+ MPH? is there any special preperation that needs to be done to the windows or stickers? Right now they say "NA INA.O G - OME F R E MAXI A ENTH " Or should I just use the next set of stickers to create a template to paint this on the window? And do not even bother saying it, because slowing down is NOT an option!
Old Oct 22, 2001 | 03:59 PM
clee130's Avatar
They're stickers... they're not going to fly off... at least mine haven't.
Put them on, run a credit card over them to get them nice and flat and sticky, peel off the covering and you're all set.
Old Oct 22, 2001 | 07:29 PM
97GreenMax's Avatar
I have had mine on for about 4 months, driving pretty fast at times, and scrubbing over them pretty good when washing it and mine have not even began to peel. Im guessing that you did not put them on right. Get some more, clean the window where you are going to put them, stick them on, rub them with something for a while (i.e. finger(starts burning), credit card).
Old Oct 22, 2001 | 07:36 PM
vandi's Avatar
Rob use alcohol, the rubbing kind ... not the drinking kind, on your window prior to sticker application. This will remove any of the detailing products you use on your glass that keep houston road slime ... and stickers from sticking.
Old Oct 22, 2001 | 11:32 PM
99NosMax's Avatar
make sure glass is clean & temp is warm so the adhesive can properly set. if not heat lightly with a hair dryer
Matt93SE
May 24, 2019 02:58 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
sliptap
Sep 30, 2015 05:57 AM
