need help getting off valve stems!
Old Nov 12, 2007 | 04:58 PM
black_maxed95's Avatar
ok so i bought a new 4th gen maxima and the tires came flat with these valve stem caps on it:
the seller did not give me a key to get them off so i am stuck with flat tires i cannot fill up. i dont want to buy another set of valve stem caps just for the key, does anyone know how to get these off without a key? Thanks!
Old Nov 12, 2007 | 06:15 PM
Nissan 6's Avatar
Use an adjustable wrench or something.....
Old Nov 12, 2007 | 06:17 PM
i used a socket and it didnt work, i found this:
How does Anti-Theft Caps work?
Each logo valve cap has a plastic insert. The key wraps around the cap as you tighten it and locks it onto the valve stem. If someone tries to unscrew the cap off of the valve stem it will keep spinning as if it is stripped. You must use the key to unscrew the cap off of the valve stem.
Old Nov 12, 2007 | 06:22 PM
nk2k2's Avatar
im assuming there plastic, get some side cutters and cut them off. there valve stem caps for christ sake. i mean they dont look good anyways.
Old Nov 12, 2007 | 06:29 PM
im well aware but cutting them off would ruin the entire valve stem making it impossible to fill my tires probably cause air to leak
Old Nov 12, 2007 | 07:54 PM
irish44j's Avatar
retired moderator
dremel.....just shave/cut it down slowly until you can pull it off....
Old Nov 12, 2007 | 09:20 PM
lightonthehill's Avatar
As a last resort, you could just cut/pull the whole valve stems out and put in new ones. They used to cost a buck each, and still probably don't cost more than a few bucks. Use a little Gulfwax or soapy water to help the new stems to slide into place. Of course installing new stems has to be done from the side of the rim that is normally inside the tire.
Old Nov 12, 2007 | 09:25 PM
eh...i will probly just leave it as is..i ordered new tires that should get here within a week and when i replace the tires the problem will be solved. i needed the new tires anyways. i was pretty much looking to see if anyone knew of a trick to get off locked valve stems without doing anything major.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
03VQMAX
Sep 5, 2015 03:47 PM
