wtf? new alternator still same power problem!?
Old Nov 19, 2007 | 10:36 AM
vq35's Avatar
new alternator...still same battery(which is pretty dead)car stayed runnin for like 4 minutes after i jumped it an took the jumper cables off....started boggin out slowly....alternator light,brake,abs,seatbelt ..all came on...??any help...thanx...i dont think the battery would come on if it was that dead..like i said it was runnin on its own for like 4 minutes be4 boggin out slowly
....btw i jus seen that the tensioner bolt broke where it spins...but it still has the other half of the screw on tight??
Old Nov 19, 2007 | 12:07 PM
SilverGLE's Avatar
I'm watching you, boy...
Your new alternator could be defective... It happened to me with a rebuilt from AutoZone. Also fix that tensioner bolt ASAP.
Old Nov 19, 2007 | 12:13 PM
Greeny's Avatar
¯\(°_o)/¯
Check your fusible links..
Old Nov 19, 2007 | 02:11 PM
vq35's Avatar
ok..i bought a rebuilt 1 on sunday (cuz i needed it bad)but i still have receipt.i still have my other alternator i took out!!..i will go 2 autozone 2morrow at 8 am an get it checked if my alternator is defective!!...but it is definitely a power problem! the tensioner bolt is broke where u tighten it> but it still has 75% of that long screw intact tight on the pulley but still intact still connected so will that cause this?btw if the battery is holdin a charge on its own for a few minut6es.. could it still be defective....thanx for the info..
Old Nov 19, 2007 | 02:12 PM
vq35's Avatar
?could u be more specific....fuses?
Old Nov 19, 2007 | 02:36 PM
vq35's Avatar
BOUT 2 GO TO AUTO ZONE IN A LIL BIT...FORGET WAITING TILL 2MORROW
Old Nov 19, 2007 | 02:43 PM
Scottwax's Avatar
That's Mr. Detail to you
A bad alternator can take out your battery. At least a couple times I've changed alternators on cars I have owned, within a couple days I've had to replace the battery.
Old Nov 19, 2007 | 02:46 PM
xkazik's Avatar
bought mine at AutoZone .. same thing happened .. got another one and its good now ..
Old Nov 19, 2007 | 05:27 PM
vq35's Avatar
update:....i went to autozone with old alternator that messed up (becuz new1 is still installed in car.taking out 2morrow)they checked it and it was fried...so my guess i bought a fried alternator!!takin out 2morrow in the am an returning it!!!updates 2morrow...
Old Nov 19, 2007 | 07:31 PM
SilverGLE's Avatar
^ Sheesh. Make sure to have them test Alt #2 before you install it and fine out it's DOA as well. A new battery would be a good purchase, as well.
Damn Auto Zone...
Old Nov 20, 2007 | 05:03 AM
vq35's Avatar
Damn Auto Zone...
yes sir..i will be 4 i install...i will get it checked at autozone!
Old Nov 20, 2007 | 05:19 AM
altimax06's Avatar
sometimes your battery can be so dead that no matter if the alt. worked or not, the car would die. I would recommend a new battery, since winter is upon us.
Old Nov 20, 2007 | 07:00 PM
vq35's Avatar
yes....new alternator...got it checked was good....an installed it, drove car cranks perfect all power is restored.... ......so faR SO GOOD... also including a $80 interstate battery had 2 purchase 2day....,...thanx for the feedback ....chumps
Old Nov 20, 2007 | 08:16 PM
Scottwax's Avatar
I figured you'd end up buying a battery too.
Old Nov 21, 2007 | 01:05 AM
vq35's Avatar
thanx yall....this site is very helpful.....
lowpost99
Oct 26, 2025 06:53 PM
maximusrising
Sep 4, 2015 06:31 PM
trungg86
Sep 4, 2015 04:58 AM
