FLOOR MATS
Soak them with Simple Green or carpet shampoo, then scrub them with a stiff brush. Use a pressure washer to spray the soap out, and then use a squeegee to remove any excess water. Dry them out of the car so that you don't get a mildew smell.
Yep, thats what I did and it worked well for me. The one thing I would change is use a wet/dry vacuem to remove excess water when finished this allows them to dry faster and also lets you see if you've missed any spots that need a little more elbow grease.
the foam kind not the spray
i just bought clear mats from walmart to cover mine so i don't have to clean them as often
Also, before you put the mats back in the car, treat them with some Scotch Guard - I did 3 treatments, and they resist staining and are MUCH easier to keep clean (just vacuum and hose off)
Be sure to let the Scotch Guarded mats dry completely OUTSIDE of the car.
