Nismo key in a 99 w/immobilizer?
Old Dec 26, 2007 | 09:31 AM
maximabebe's Avatar
Can the 'all metal' Nismo key be used in my 99 SE-L with the immobilizer if I were to take the chip out of the OEM key and plant it somehow within the steering column close-by to the ignition cylinder so that the signal is still picked up? Has anybody done this before? I have searched but without luck.
Old Dec 26, 2007 | 09:43 AM
99BlackMaxMS's Avatar
Rather than just take the chip out, why dont you just keep the original key taped under the dash or within range from the immobilizer. Then you can use any key (whether it is a $2.00 hardware store special, or the NISMO key that you are talking about). What's wrong with the original key?
Old Dec 26, 2007 | 09:48 AM
maximabebe's Avatar
The only issue with the original key is that the corner where the chip is positioned has a small crack in it. I don't want to get moisture in there or anything as the gap is big enough for water to seep in. Taping the entire key under the dash may be too far away from the ignition, no? Plus, leaving a functional key in the car makes me feel a touch unsafe.
Old Dec 26, 2007 | 01:56 PM
njmaxseltd's Avatar
Keeping "the chip" constantly in range of the ignition is basically making your security system immobilizer useless.
Not exactly a smart idea.
Old Dec 26, 2007 | 10:46 PM
maximabebe's Avatar
Right, but with a nice aftermarket alarm it should be fine.
Old Dec 30, 2007 | 06:54 AM
BenStoked's Avatar
Jesus was a Zombie.
an idea: cut the key so that it just looks like a fob, and put it on the keychain with the nismo key.
just an idea.
Old Dec 30, 2007 | 07:56 AM
maximabebe's Avatar
hmmm.. possibly ben
Old Dec 30, 2007 | 07:59 AM
black_maxed95's Avatar
just an idea.
thats what i was thinking, just keep both keys on the keychain.
Old Dec 30, 2007 | 08:12 AM
ShiftVQ35
you can try it but i doubt that will work. i always have thought that the key has to be inside the ignition because there is a ring that goes around the ignition switch itself. on another note, who still sells the nismo key?
Old Dec 30, 2007 | 05:31 PM
BenStoked's Avatar
Jesus was a Zombie.
ebay's got some, so there are places out there to find them
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
maxinout93
Oct 16, 2015 02:53 AM
ToTheMax305
Sep 23, 2015 09:11 PM
