help with axle replacement
2000 Max, auto tranny
I am trying to remove the pass side axle as one piece ... Is this possible??
There seems to be not enough clearance for the bearing bracket to pass out the side ...? It is hitting the front of the wishbone and power steering pump, and engine at the oil filter ...
Does the exhaust have to be lowered? To spin the bearing support down?
I thought the axle would slide right out the side ????
This section is for tools for your garage, might wanna have it moved. Are you trying to remove the axle with the mounting braket attached? I have a 4gen and since the set up should be the same...there are three bolts that hold the axle bearing to that bracket, remove those and the axle will separate from the bracket and you should be able to slide it out (in one piece). The braket should stay in place attached to the block. Good luck
Originally Posted by The Rules of The Garage
- This section is not for specific maxima install questions. If you need to know how to install an intake on your 4th gen, it's probably best to ask it in the 4th gen section.
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
