PCV Valve Removal Question
Old Oct 26, 2001 | 01:37 PM
GR8SOUND's Avatar
I've located the PCV valve but am having trouble getting to it to remove it. Does anyone have any suggestions as to what needs to be moved or removed in order to make this job easier? Thanks.
Old Oct 26, 2001 | 02:41 PM
BSwithTF's Avatar
I hope you can follow this.
When I changed mine, this is how I did it. The PCV is connected to a metal line by a small piece of rubber hose. There are two bolts that hold that metal line down. The bolts are 10mm. Remove these bolts and this will allow you to move the metal line around a little bit. Move the clamp that holds the rubber hose to the metal one. Disconnect here first. Now you should be able to pull on the rubber hose and the PCV should pop out. Hope this helps.
Old Oct 26, 2001 | 05:24 PM
njmaxseltd's Avatar
Re: I hope you can follow this.
That how I got it out also.
Old Oct 26, 2001 | 09:19 PM
GR8SOUND's Avatar
Thanks. That really did help.
Old Oct 28, 2001 | 12:03 PM
Stillen_I30's Avatar
damn, wish i knew that last night...thats when i changed mine out but didnt see the 10mm bolts to that metal hose. oh well, got it out anyway, took a while to pry out the pcv from the crankcase though...turns out my old one rattled anyway and didnt really need to replace it. the hose was a b*tch to get on and off though!
Old Oct 28, 2001 | 07:06 PM
Dahnryman's Avatar
dumb question
but what does it doo and why do you want to take it out? other than to replace it?
Old Oct 28, 2001 | 09:52 PM
Ravq's Avatar
Re: dumb question
A PCV Valve feeds crankcase blow-by gases into the intake manifold to be burned with the normal air/fuel mixture. There is no strict interval for replacing it but is good to check it occassionally in case it is clogged.
The Frye
Sep 2, 2021 11:03 AM
lowpost99
Sep 8, 2015 05:06 AM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
Johnny9595
Sep 3, 2015 05:18 AM
