Boost Sensor Relocation?
Old Oct 26, 2001 | 01:40 PM
GR8SOUND's Avatar
I've replaced the stock air intake with a Stillen intake on a 97SE and wanted to remove the rest of the stock air flow tubing but the boost sensor is still attached to it. Is there anywhere else I can mount this? Does anyone have any pics? Thanks!
Old Oct 26, 2001 | 02:08 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Zip-tie it to something.
Old Oct 26, 2001 | 08:58 PM
Nismo's Avatar
mine is zip tied next to the battery
Old Oct 26, 2001 | 09:23 PM
GR8SOUND's Avatar
Results...
Okay. I pulled the rest of the tubing out only to find that there was another sensor attached to the tubing. It runs from a black box right after the K&N cone to the tube and when disconnected, sends a check engine error. Anything I can do to eliminate this?
Old Oct 26, 2001 | 09:58 PM
Eric L.'s Avatar
Re: Results...
You are referring to the intake air temp sensor. According to the FSM, it is not directly used to control the engine system, but rather for diagnostic purposes only. So, if you want to remove the air duct, just zip tie the intake air temp sensor somewhere else.
Old Oct 27, 2001 | 09:47 AM
fnkmaster's Avatar
i zip tied mine to one of the vacuum hoses right next to where it originally was.
my03maxima
Jul 28, 2024 07:40 AM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
