Stupid question
Old Jan 26, 2008 | 06:12 PM
ChromeSE5's Avatar
Stupid question
So I took off my spark plug cover about 3 years ago and lost all the bolts. Anyone know what size they are?
Old Jan 26, 2008 | 11:05 PM
shift_2kmaxima's Avatar
good job man
hahah jk.
i have no idea man, good luck getting some.
huso
Old Jan 26, 2008 | 11:23 PM
MrGone's Avatar
You have bigger issues, like getting the correct width tyres on those wheels.
Old Jan 26, 2008 | 11:28 PM
kzoosho's Avatar
Thats the way they are suppose to be.
Old Jan 26, 2008 | 11:29 PM
!PrjctMax!'s Avatar
Jay Dee Emm
Old Jan 27, 2008 | 11:48 AM
MrGone's Avatar
no
Old Jan 27, 2008 | 11:57 AM
kzoosho's Avatar
no
Yea. They are stretched. That is the way he intended to use them. same with mine. His are stretched more than mine.
Old Jan 27, 2008 | 12:48 PM
MrGone's Avatar
Intended != Correct
Old Jan 27, 2008 | 01:28 PM
nismos14's Avatar
§è~® f®ÈÄk
Yuck.
Old Jan 27, 2008 | 01:33 PM
mjk's Avatar
mjk
Head shot!!!
ah snap
Old Jan 27, 2008 | 03:39 PM
Fast1one's Avatar
Intended != Correct
Who cares, modifying a car is about stretching boundaries (no pun intended)...Just because you don't have the ***** to ride that low and that wide, doesn't mean he doesn't
Old Jan 27, 2008 | 03:41 PM
kzoosho's Avatar
Well put
Old Jan 27, 2008 | 03:48 PM
Grand_hustle17's Avatar
even though im a fan of tires flushed with the rims, in some cases (like this) it's ok to do that, obviously he has his reasons... but to answer i dont know the size but i will pass by nissan and ask a friend
Old Jan 27, 2008 | 05:59 PM
MrGone's Avatar
Sacrificing safety isn't a measure of ones "*****', now stupidity on the other hand...
Old Jan 27, 2008 | 08:12 PM
Fast1one's Avatar
Oh please, please give me some substantial, credited evidence that stretching tires sacrifices safety in a significant way...cite your sources...
Obviously you can over do it and pop a bead, but I have only heard of two instances of someone actually popping a bead in a daily driver, and that was a 205/45 on a 10 inch wide wheel Even if if it does decrease the performance (which I am certain it does), the gains from using a performance summer tire over an O.E. standard all season will outweigh most of the negatives when daily driving....
Spirited/road course driving, thats a different story...
Old Jan 27, 2008 | 08:46 PM
EnervinE's Avatar
i has college
tyres
Are you bri-ish?
Old Jan 27, 2008 | 09:52 PM
MrDicks95SE's Avatar
Offset Is Everything.
i lost 2 of mine already. damn things are small to begin with.
Old Jan 27, 2008 | 09:56 PM
ChromeSE5's Avatar
Well if you have the rest I'll go with you to home depot or ace hardware and I'll buy you a brand new set of four!
Old Jan 27, 2008 | 09:59 PM
i was just at home depot today... i might go later this week. if i find em ill pick some up for ya and mail em down.
Old Jan 28, 2008 | 01:23 PM
Old Jan 29, 2008 | 08:29 AM
wpm3blackmax's Avatar
no clue. Go to the junk yard and pull some originals
Old Jan 30, 2008 | 11:49 AM
kzoosho's Avatar
Wow all this because we are different. O well my stretched 215/30/18's on a 8 inch rim has done me fine.
Old Jan 30, 2008 | 11:54 AM
nismos14's Avatar
§è~® f®ÈÄk
So did you guys with the dramatically stetched tires, did you have any problem getting the installed at shops? Did any of them refuse?
How much worse is your handling?
Old Jan 30, 2008 | 12:09 PM
Fast1one's Avatar
I have asked many shops that... they have all told me that they much rather stretch a tire then squeeze a wide tire on a tiny rim, its not as hard as it looks...just a lot of lube
My tires are hardly stretched, but I have noticed a decrease in side wall flex through corners. A negative effect is a decrease in straight line traction since the tire is aired up a little more...
Stiffer side walls is the most noticeable outcome, again you CAN over do it, but its a must if you are slammed and still want the rim flush or even poking over the fender. It gives the needed clearence when the suspension compresses...
Of course with solid rear beams, there is no camber compression, so stretched tires won't really help, you will eventually hit something if you are flush with a big bump...
Old Jan 30, 2008 | 12:30 PM
kzoosho's Avatar
No. But not everyshops tire machine can do it. Bug chains discount belle they can and will. Think i stretched mine to the point that its 2.5 inches shorter than the oem combo.
Old Jan 30, 2008 | 12:54 PM
ChromeSE5's Avatar
Stretched tires is a matter of taste when it comes to style. When it comes to safety, there is a huge internet debate as to whether the tires (specifically the beads) will hold up. I have only heard of two cases where the beads popped off. This was on two separate occasions at a drift day. I am not worried at all because I don't do any spirited driving. Bippu guys are running even more serious stretches and I haven't heard of one guy popping beads. Well, here are two threads... the first two Google ones that came up when I searched "stretched tires".
1st: http://forums.vwvortex.com/zerothread?id=2234638
2nd: http://forums.bimmerforums.com/forum...d.php?t=541138
BTW, back on the MAIN TOPIC which I originally posted, I did end up finding a screw that fit perfectly for the cover. I am going to home depot tonight to get a whole set. I'll post the size later.
Old Jan 31, 2008 | 09:15 AM
L.M.L.
i've got a few oem spare bolts
Old Jan 31, 2008 | 11:31 AM
hot_wax_tree's Avatar
oh wow really I would have never guest that's what he was going for.
Old Feb 1, 2008 | 01:56 PM
ptatohed's Avatar
Licensed to Spell
Yeah, I guess it's kind of a stupid question. But the question isn't quite as stupid as the thread title.
I'm not quite sure why you are asking. It's not like you are going to find these unique bolts at a hardware store, are you? Just go to Nissan and order them. You don't need to know the size for that.
P.S. Why do people start sentences with "so"?
Old Feb 1, 2008 | 02:13 PM
ChromeSE5's Avatar
How can you find the bolts at the hardware store when you don't know the size? Is it so I can spend $30 worth of bolts and screws to find the magical four? And why go to nissan when I can ask someone on the forums if they know?
Old Feb 1, 2008 | 02:27 PM
kzoosho's Avatar
3 weeks later and a mind short
Old Feb 1, 2008 | 02:50 PM
ptatohed's Avatar
Licensed to Spell
I'm suggesting that you won't find them at a hardware store. Aren't these unique, special bolts with the cylindrical hex head?
Old Feb 1, 2008 | 03:05 PM
ChromeSE5's Avatar
Ok I get what you are saying. Actually I did find a screw in my garage that had a regular philips head on them that fit. I was more worried about the threading since I didn't want to mess anything up. I'll post up the thread size when I have a chance to go to home depot. I know they have the hex cap screws/bolts at home depot and lowes but they are close to being $1 a piece.
Old Feb 1, 2008 | 08:53 PM
ptatohed's Avatar
Licensed to Spell
The Home Depot near me has a "screw fitter". So if you have one example of what you need, you can bring it in and try threading it in the different holes. That will tell you diameter, metric/english, thread pitch, etc. Or try good old fanatic rock. That guy rules. He'd probably drop a handful in an envelope and send them off to you for $5.
Old Feb 2, 2008 | 07:38 AM
kzoosho's Avatar
U know what. I neva thought about him till you siad somethign man. Yea shoot him a pm and he can send you all kinds of screws.
Old Feb 2, 2008 | 04:23 PM
Agent R31's Avatar
Originally Posted by EnervinE
Are you bri-ish?
isnt that how you spell it... thats how i spell it
beint japanese it will almost certinaly be a metric thread, at a guess M6, (they have a 10mm head) if its imperial, ur ****ed too many types for me to throw a guess at.
go to a bolt shop/engineering supplies store and ask a sales assistant to help you, if you have the extra $$ get some nice stainless steel socket head cap screws or dome head cap screws
Old Feb 2, 2008 | 04:28 PM
Agent R31's Avatar
also dome head cap screws is a nice way to finish off the front fenders, thats what i have done in my skyline, put them on the fenders so when you open the bonnet there is some nice shiney scerws there!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
