Foamy Gear Oil?
Old Feb 8, 2008 | 01:11 PM
maxitech's Avatar
Foamy Gear Oil?
So...my car sits in the garage all winter. I just got done rebuilding my brake calipers and putting it all back together and the long back road by my house is completely dry and it's nice and sunny out.
Now, my tranny has always leaked since I did the tranny swap (still have automatic support bracket). This will be addressed shortly as I swap in the VLSD unit.
So since the car has been sitting w/o being started for about 2 months now, I decided to check the gear oil level and POSSIBLY take it for a mid-winter drive on the dry pavement.
I have the car completely level on the ground (not jacked up) and I take the filler plug out of the tranny. What leaks out is a considerable amount of foamy gear oil. It's still cool, as I've had the car running for about 10 minutes but haven't moved it at all. I've had this tranny slightly overfilled before but the oil that drips out then looks good.
What gives with the foamy gear oil? The tranny hadn't been engaged to even froth it up???
Old Feb 8, 2008 | 01:18 PM
MrGone's Avatar
if the clutch is engaged the input shaft spins
Old Feb 8, 2008 | 01:19 PM
maxitech's Avatar
Ah, but why the froth? Haven't seen it before....
Old Feb 8, 2008 | 01:20 PM
MrGone's Avatar
What kind of gear oil are you using? Any additives?
Old Feb 8, 2008 | 01:27 PM
maxitech's Avatar
Just good old Napa gear oil. No additives. Always benn fine in the past.
Old Feb 8, 2008 | 01:30 PM
nismology's Avatar
Overfilled.
Old Feb 8, 2008 | 01:31 PM
maxitech's Avatar
Originally Posted by nismology
Overfilled.
Plain and simple?
Old Feb 8, 2008 | 01:32 PM
MrGone's Avatar
Might be temperature related but...
Just making sure, was the engine running when you checked the gear oil? While frothing typically isn't a good sign if it's just a little bit I wouldn't be too concerned. If you really want to know check it with the engine off after it's warmed up, just don't burn yourself
Old Feb 8, 2008 | 01:49 PM
nismology's Avatar
The fact that gear oil poured out on level ground tells me it's been overfilled. You should have to reach in slightly with your finger to encounter any fluid.
Old Feb 8, 2008 | 04:22 PM
maxitech's Avatar
Yeah, I know...when I drove the car daily (summer and fall) I would tend to put a bit more in just so I wouldn't have to fill it as often...Problem will be remedied when I put a different tranny in shortly...
Old Feb 16, 2008 | 09:55 AM
NisTech's Avatar
where is it leaking?
And don't overfill your tranny! you will cause even more leaks
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
