Project: Installing Shock Sensor onto Factory Alarm
Old Oct 30, 2001 | 06:02 PM
RussMaxManiac
I will be installing a Dual Stage Shock Sensor on our Factory Alarm systems. Our Factory Alarms are fair for what they do. Personally most of us would keep them if they had shock sensors and other type of connections. I will be only using the full trigger on this sensor since our alarm does not have pre-warns.
This project should be completed by this weekend with pictures and a detailed write up. I will be picking up the supplies tomarrow after work hopefully to complete this job. The factory alarm does not work off a negative system, so I will be using multiple components to make this work and will have it all listed when the job is completed after I make sure it works properly.
Total project $$$$ About $20 bucks total.
Looks like I will be the first person to attempt this. No one else has every posted in 6 yrs of ever doing this. I am willing to be the beta boy!
Old Oct 30, 2001 | 06:21 PM
190hpKiLLA's Avatar
Granny Driven
Re: Project: Installing Shock Sensor onto Factory Alarm
Good luck. I would like to install the sensor two.
Old Oct 30, 2001 | 07:40 PM
Vinipux's Avatar
you're the man bro, that's definatly something many of us on the forum would like to have, good luck, don't fry anything
Old Oct 30, 2001 | 07:43 PM
RussMaxManiac
Re: Re: Project: Installing Shock Sensor onto Factory Alarm
I just got done testing it, and it did set the alarm off per my theory! So I will work on actually installing it this weekend properly and take all pics and instructions. Including prices, and what to buy from where.
Basically the price has now dropped from $20 to $12 to install one.
Old Oct 30, 2001 | 07:50 PM
«§»Craig B«§»'s Avatar
good job Russ
also, if you dont know already, you can convert a + to - or - to + pretty easily using a single relay
if you want to know more, let me know and I'll explain it, but it's pretty simple
Old Oct 30, 2001 | 08:07 PM
RussMaxManiac
Originally posted by «§»Craig B«§»
good job Russ
On a shock sensor though you do not want to use a relay, unless you can turn off the shock sensor while driving or that relay will just be clicking like crazy. The way I have is simple, no need for anything additional really.
Old Oct 31, 2001 | 05:51 AM
Re: Re: Re: Project: Installing Shock Sensor onto Factory Alarm
that's true, but you could wire it up so it couldn't activate when the car was on ie something like wire the - coil on the relay to the ACC + wire so it or the stock alarm probably has an armed output somewhere that you could use for the coil on the relay
anyway, sounds like you've got it under control though so I'll be quiet now
good luck, sounds cool
Old Oct 31, 2001 | 06:08 AM
1MAX2NV's Avatar
Hmm...sure..you are the first one I have a shock sensor on my factory alarm since 1999.
This is the shock sensor I have.
http://www.codl.com/its.html
Old Oct 31, 2001 | 07:38 AM
njmaxseltd's Avatar
Excellent idea! Keep us posted I'd definately be interested in putting that in my car as well.
Old Oct 31, 2001 | 07:50 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
I thought Russ was a veteran.....
This isn't the first time this has been done. I would prove it, but that requires effort.
Old Oct 31, 2001 | 07:54 AM
Sprint's Avatar
http://forums.maxima.org/search.php
Old Oct 31, 2001 | 08:17 AM
bill99gxe's Avatar
Re: Re: Re: Re: Project: Installing Shock Sensor onto Factory Alarm
That only could have prevented Tony from repeating himself, as shown in this post:
http://forums.maxima.org/showthread....sensor+factory
which was found as a result of this search:
http://forums.maxima.org/search.php?...der=descending
Maybe Russ's angle is from a cheapness standpoint?
Old Oct 31, 2001 | 03:58 PM
RussMaxManiac
To old to show proof?! hehe jk. Well I haven't really ever seen it discussed, so I assumed it has never been done. But i will do a write up and make it official then.
Old Oct 31, 2001 | 04:02 PM
RussMaxManiac
Re: Re: Re: Re: Re: Project: Installing Shock Sensor onto Factory Alarm
You the man! :P Thanks for the links..... Yeah mine is ALOT cheaper. $10 bucks for the sensor . The only thing I am not sure is if the alarm will shut up after going off a while.
Old Oct 31, 2001 | 07:33 PM
Riot^'s Avatar
Keep us posted!
Old Nov 1, 2001 | 06:16 AM
cooler2000's Avatar
let us know when you are done! I am looking for way to make my alarm to chirm when i lock car, and arm rear doors with sensors too!
make it active from passive!
Thanks!
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
