warantee on the KYB AGX???
Old Nov 8, 2001 | 04:17 PM
Vinipux's Avatar
hey guys, I know the Koni has lifetime warantee, what about KYB AGX? what kind of warantee does it have, because if the shocks go in 2 years and there is no warantee, what are you going to do??? I'm thinking of getting the KYB's that's why I'm asking
Konstantin
thanks for any help
Old Nov 9, 2001 | 05:48 AM
AndyXXL's Avatar
Re: warantee on the KYB AGX???
You just got your Koni last summer, why do you need new shocks?
Old Nov 9, 2001 | 06:08 AM
njmaxseltd's Avatar
KYB AGX, Just got em yesterday. Lifetime Warranty to the original owner.
Old Nov 9, 2001 | 06:15 AM
97GLES's Avatar
thats good to know. i got my agx and i didn't even check for the warranty.
Old Nov 9, 2001 | 07:22 AM
Lime's Avatar
sweeeeeeeeeeeeeeeeeeeeet. : )~ that will be good since I might auto-x muahahaha.
Old Nov 9, 2001 | 09:34 AM
DhaMax's Avatar
wooooouuuuu! this is craziness, i just installed my b+g and kyb agx's. five hours not including the breaks i took.
Well finally i m done with complete tied suspension. My car just sits during turns. Feels weird sometimes, but i'll get used to it. All i can say is get the agx's, set it to 2/4 and get ready to bring curves (on road only )and high speed together. warranty on agx's is life time as long as you do not lower the car more than 1.5".
Old Nov 9, 2001 | 09:58 AM
Asian_N02's Avatar
How much firmer is your ride? do you feel more bumps now compared to stock?
Old Nov 9, 2001 | 11:16 AM
matt calder's Avatar
:. warranty on agx's is life time as long as you do not lower the car more than 1.5".
D'oh that sucks, I guess I dont have a warranty then.
Old Nov 9, 2001 | 11:19 AM
Vinipux's Avatar
how would they find out if you had your car lowered more than 1.5 inches?
Old Nov 9, 2001 | 11:25 AM
they can probably tell by looking at it. Lowering more that 1.5 would put to much stress on the struts and make them fail....just a guess
Old Nov 9, 2001 | 11:28 AM
Vinipux's Avatar
REALLY??? you're telling me that a smooth 2.5 inch drop will have more stress than a bumpy 1.5 inch drop??? I don't think so
Old Nov 9, 2001 | 11:32 AM
AndyXXL's Avatar
What are you talking about? The lower your car sits the more stress you put on shocks. It doesn't matter if you ride is smooth or bumpy.
Old Nov 9, 2001 | 11:35 AM
Vinipux's Avatar
HELLO, what would give you more stress, me putting a 10 lbs weight on your stomach when you're laying down, or dopping that 10 lbs at 20 mph on your stomach????? come on andrey, you should know who you're talking too
Old Nov 9, 2001 | 11:43 AM
AndyXXL's Avatar
WHO?!?! That's a focking weak reply "know who u talk to" like you're the **** and I don't know what the fock I'm talking about. Go **** youself man, and don't talk to me like that!!!!
Old Nov 9, 2001 | 11:51 AM
Lime's Avatar
whoahhhhhh chillllll guys!!!!! I just have the safe, comfy drop with the H&R's, so I'm not worried. They are good springs too; really feel nice even with the suspension trying to bounce. I believe that the greater the drop, the more stress you put directly on the shocks/struts.
Old Nov 9, 2001 | 11:54 AM
Alright, think about it. The car comes with factory speck struts, They ride alllllllllllooooooootttttttt better at the stock ride height than lowered 2.5 inches. Same goes for the KYB's, if you put to much stress on them, when you hit a bump and compress the strut, it cant compensate for the amount of stress. Therefor it can possibly malfunction, snap in half etc. This is why people who have the old cattman coilovers keep on breaking their back struts. They have it to low and putting to much stress on it.
Andy:
Old Nov 9, 2001 | 12:04 PM
njmaxseltd's Avatar
The shorter the suspension travel is (DROP) the more SPRING FORCE is needed in order to keep the car's suspension from bottoming out. To achieve less travel, the spring need to put more force out. Sport springs are stronger then OE springs and do put more force out that a shock needs to be able to dampen and control.
Example, OE suspension - you hit a dip, the spring can compress perhaps 2 - 3 inches, then rebound nice and smooth. Nice and easy for the struts/shocks.
Sport springs - you hit that same dip, the spring need to put more force out in order for you NOT to compress the spring 2 - 3 inches, teh sport spring only lets you compress 1.5 inches. This greater force pushes hard to resist the compression but also pushes up MUCH harder then OE springs. I believe the upward force is called JOUNCE? Someone correct me if I'm wrong here. So the shocks/struts need to be able to control the excess force sport springs put out.
Any performance shop will confirm that sport springs put out more force then OE equipment. Otherwise our cars would ride exactly the same with shorter/sport springs as they do on OE springs. And we all know thats not true at all.
Old Nov 9, 2001 | 12:32 PM
srbarnes4ever's Avatar
I believe the term is REBOUND but I have heard jounce used before also. You're right though you need stronger struts (IN GENERAL) to compensate for stronger spring rates.
If you have shorter springs with the identical spring rate as stock, you run the risk of compressing too far on a bump and hitting the bumpstops...so you may NOT ride the same, in fact it may be quite dangerous under the right (or wrong!) circumstances....My $.02 worth.
Old Nov 9, 2001 | 12:47 PM
Mustang1999's Avatar
What do you have your backs set on? I have 3/4 in the front and 6/8 in the back... talk about stiff....
BkGreen97
Apr 2, 2016 05:47 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
maxima-junky
Oct 7, 2015 06:13 PM
dvcamp
Sep 18, 2015 10:17 AM
