No Spark in #2 cylinder
Old Nov 8, 2001 | 06:46 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
hummm
seems like i get no spark at #2 cylinder. we swapped coils and that didnt do anything. sucks...worked on it all day and couldnt figure it out. anyone can help out?
Old Nov 8, 2001 | 06:51 PM
Sprint's Avatar
put a spark plug in..
check the plug wires..
check the distributor cap..
Old Nov 8, 2001 | 06:57 PM
RussMaxManiac
Check the plug wires or distributer cap?!!??! lol, VQ doesn't have a cap, and it has direct ignition so no wires. hahaha
Old Nov 8, 2001 | 07:02 PM
Tai Mai Shu's Avatar
sprint your so funny
Old Nov 8, 2001 | 07:06 PM
RussMaxManiac
His part time job is a commedian!!!
Old Nov 8, 2001 | 07:18 PM
Sprint's Avatar
really?
Old Nov 8, 2001 | 08:22 PM
Dirksmoothe's Avatar
wow
well, I will say that I didn't know that. I honestly thought that the VE was the only direct Ignition engine in the maxima family
cool, see, this thread wasn't completely worthless.
Old Nov 8, 2001 | 11:32 PM
Turbo95Max's Avatar
actually it was completely worthless cause it has nothing to do with the orginal question..anyways, if anyone has any clue or advice id really apprecaite it. I spent alot of time today and still couldnt figure it out
3 wires on the Ignition coil, Verifed there is voltage, verified there is a good ground, so i think the only thing left is the trigger/signal wire from ECU. any other suggestions? maybe an out of phase cam or crank sensor causing a weak spark??
Orginally i did have a P1320 code which was Ignition primary circuit. I follwed the service manual and checked out the condenser, it was out of spec so i replaced it and that did jack tho. pleaes help@!
Old Nov 8, 2001 | 11:37 PM
emax02's Avatar
Try swapping the 2 Crank shaft position sensors and the camshaft sensor. It only takes about 10 minutes.
Old Nov 9, 2001 | 12:39 AM
Turbo95Max's Avatar
i dont have spare ones.....
we did some more poking around and turns out the voltage signal to #2 is low. All others are higher...dunno what this means tho...SUCKS
Old Nov 9, 2001 | 12:46 AM
emax02's Avatar
Hmm, damn I really wish I could help you out, if I lived near by I would. If you still suspect the CPS's or CPS is at fault I would definatly try testing them with a volt meter. Also make sure all the wires to the coil is in working order, maybe a wire was damaged when you put the motor in? Other then that theres ground wire{s} but you allready said you double checked them?
Old Nov 9, 2001 | 01:07 AM
Turbo95Max's Avatar
i havent checked the cam or crank sensors yet. mayube ill do that when i get back from LA. Its weird cause its only the #2 cylinder. oh well we'll see. we verified the wire wasnt open or shorted. The coil is good, and i dunno what else to check....ughhh
Old Nov 9, 2001 | 06:12 AM
njmaxseltd's Avatar
and turn the key to the start position
Old Nov 9, 2001 | 07:06 AM
MardiGrasMax's Avatar
Visually inspect the connectors on the harness plug. If they dont grip onto the coil terminals good you will have bad connections. Compare the harness plug from #2 to another working cylinder.
Old Nov 9, 2001 | 11:11 AM
deezo's Avatar
Re: No Spark in #2 cylinder
hummm
I feel for you guys that just want to make something work and then something rediculous always hinders the finished product.
jmlee44
Oct 2, 2022 02:13 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
