Wheel Stud Question-Will these work? (Pic)
Old Sep 11, 2008 | 02:17 PM
black_maxed95's Avatar
Ok so I ordered 20 50mm (length) 14mm (knurl) from ichibausa.com. I first receive 10. They look great but I only got 10. These first ten look like the stud shown in the left of the picture. So I call them up, they agree they messed up, they send me another 10 in the mail. Now these next 10 look different. They are the right measurements but look at the splines. These 10 have a squared edge and the splines barely if at all stick out above this edge. Also the spline spacing is larger. Now the stud on the left I took to a grinder to try and make it look like the first 1. What do you guys think? Should I try to get another set of 10 like the first (which have already worked good) or are the gold ones fine too?
Old Sep 11, 2008 | 02:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
IMO the taper edge just makes it a little better to install...other than that if the fitment (dia) is correct you "should" be ok.
Old Sep 11, 2008 | 02:24 PM
are there splines in the wheel hub that the wheel stud splines fit into or is the hub smooth? Im wondering cause the spacing of the splines is different on the two types.
The last thing i want to do is strip the studs or the hub and have to drill out the studs (been there done that)
Old Sep 12, 2008 | 05:23 AM
njmaxseltd's Avatar
The splines don't have to line up with anything, they are there to hold the stud from spinning once it's installed.
They look perfectly fine, install them and be done with it.
Old Sep 12, 2008 | 06:42 AM
matty's Avatar
Whats the reason to replace these ? Comman wear item ?
Old Sep 12, 2008 | 06:52 AM
ok thanks, i just wanted to make sure.
Well Ive always had 20mm spacers in the front and over time ive had 3 break. (1 due to just taking the lug not on and off, and the other two I had my wheel come lose once and the vibrating wheel snapped 2 off.) But I ordered 20 cause Im going to replace all the stock studs in the back and add 20mm spacers there too to match the front.
trasmadean
Feb 1, 2017 08:20 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
