Painting Muffler and Inside of Tips
Old Nov 6, 2008 | 07:29 PM
Banginbeats3's Avatar
I have a 6th Gen and I've read somewhere that someone painted their muffler black and the inside as well so that it looks like a single pipe. Im basically looking for the type of paint that I would need to use to do this. There will be chrome still but its more like blacking out the muffler. Also, since I was rear ended I can litteraly pull the tips off the new muffler they installed, is there any way of keeping them in place without welding?
Old Nov 6, 2008 | 09:00 PM
maximase86's Avatar
I love lamp.
Paint over chrome, especially with high heat won't work so well. You'll probably have to sand it for the paint to stick. You will need to use really high-temp paint. The muffler/tips will get extremely hot.
S
Old Nov 7, 2008 | 03:27 AM
Arisotezza18's Avatar
I painted my muffler black using high temperature engine paint. Should work for you too. You will probably have to sand the areas you are going to paint and tape off parts you want to leave chrome. You can get the paint at most auto parts stores.
Old Nov 7, 2008 | 03:33 AM
Your definitely gonna have to sand it down for paint to stick. High-temp engine paint will work fine once you sand the chrome. Good luck.
Old Nov 7, 2008 | 06:41 PM
How many coats would you recommend, and I appreciate the feedback fellas!
Old Nov 7, 2008 | 06:53 PM
NismoMax80's Avatar
SuPeRmOd
with time they turn black anyway.
I say three coats with lots of cure time between each.
Old Nov 14, 2008 | 03:42 PM
pezfallout's Avatar
2nd. I would apply at least one coat of primer, three coats of paint and a non gloss protective coat or two. This will keep it looking great for a long time. Lots of cure time and low humidity will keep it all from flaking prematurely, too.
Old Nov 15, 2008 | 12:03 PM
302Xplorer's Avatar
Forget painting it, go with diamond plate!
302X - Going for a quick 15
Old Nov 19, 2008 | 08:09 AM
LUNATIC's Avatar
How about powder coating? Try Eastwood
Old Nov 19, 2008 | 10:53 AM
Drockb418's Avatar
dont bother its not that big of a deal
Old Nov 20, 2008 | 09:39 AM
Norm Peterson's Avatar
1. Plan on repainting them every so often, regardless of paint or preparation.
2. Two or three tacks with a MIG welder will fix the loose tips issue. Can't think of any other way to do it that'll work anywhere near as well. A garage or even a muffler shop ought to be able to do it for cheap as it's about a 5 minute job.
Norm
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
