LED Lighting
Old Nov 7, 2008 | 09:27 AM
Prophecy99's Avatar
LED Lighting
Generally Speaking if LED lights allways draw power(stay slightly lit when car is off) are you required to provide some kind of support (ex: current limiter or volt meter) to counter act the constant power draw?
I am just throwing it out there becasue I dont know alot about automotive LED lighting and am just curious. I breifly read talk about this and never concluded a true answer.
Thanks in advance
Old Nov 7, 2008 | 10:47 AM
kzoosho's Avatar
U usually run a voltage regulator to regulate it from spikes. There is nothing extra you would need to run them with the car off.
Old Nov 10, 2008 | 09:07 AM
Prophecy99's Avatar
inother words... can I just start pluggin in my LED lights and be done with it?
Old Nov 10, 2008 | 10:08 AM
njmaxseltd's Avatar
LED's will only draw power when there is power being supplied to them.
When your car is off, no power is supplied to the lights so they can't pull anything.
Old Nov 10, 2008 | 10:15 AM
Prophecy99's Avatar
so in other words ^^... can I just start pluggin in my LED lights and be done with it?
Old Nov 10, 2008 | 04:31 PM
Froggmann's Avatar
Yes
Old Nov 10, 2008 | 04:59 PM
michaelle8885's Avatar
exactly what type of LEDs are you talking about? I have LED bulbs and they require nothing except taking out the stock filament bulbs and putting in the new LED bulb, that's it, and they require less power consumption and produce more luminance.
Old Nov 11, 2008 | 09:55 AM
Prophecy99's Avatar
in general any LED bulb replacing a stock incandesent...
i was just thrown off after seeing my first LED lights. (courtesy step light/interior door light).. allways stay slightly on..after the car was turned off.
and now im doing the ignition light... due to sharpie wearing off.
Old Nov 11, 2008 | 04:56 PM
Squirrel82's Avatar
I thought that there was just energy left in the LED bulb assembly to stay dimly lit for a few minutes.
Not sure though.Id check light forums.
Old Nov 14, 2008 | 03:17 PM
pezfallout's Avatar
If something stays on after power has been cut there is probably a short in the wiring somewhere. I'd hit the terminal posts with a multimeter.
MaxLife17
Jun 27, 2019 01:37 PM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
