Coolant temp sensor and oil pressure sensor threading size?
Old Nov 12, 2001 | 10:41 AM
1MAX2NV's Avatar
Are they in metric, AN or NTP? I'm looking for some t-fittings so I can run aftermarket gauge senders and the factory sensors at the same time.
Old Nov 12, 2001 | 12:01 PM
1MAX2NV's Avatar
Who else has after market water temp gauge besides Matt Calder?
Anyone? Where did you put the sender? If it's at the coolent temp sensor, did you have to get a custom t-fitting or adaptor?
Old Nov 12, 2001 | 01:01 PM
matt calder's Avatar
Old Nov 12, 2001 | 03:36 PM
Chunger's Avatar
My other car is a Hybrid
It's not NPT... at least for the oil sender... AUTOMETER makes an adaptor 1/8" NPT to MBPT (or something like that.. Metric). I have it at home.. I'll check tonight and post.
I was looking for a T fitting as well but couldn't find the right one. But, since I just put on a S/C, I found a -04AN T'ed to a 1/8" NPT to splice into my S/C oiling line. I had to get an extra 3' -04AN line, though.
Old Nov 12, 2001 | 07:54 PM
Chunger's Avatar
AUTOMETER part: Metric Adaptor #2269 - '1/8" NPT to 1/8" BSPT for use with oil pressure and electric water temperature gauges'
Old Nov 13, 2001 | 10:39 PM
1MAX2NV's Avatar
Thanks Chunger. You are probably one of the most helpful person on here
Old Nov 13, 2001 | 10:41 PM
1MAX2NV's Avatar
I found the page
http://www.autometer.com/hp/2001_cat...sories/87.html
Old Nov 14, 2001 | 12:31 AM
Chunger's Avatar
NP... double check with the store just in case... I compared it to the part of the T from the S/C kit that fit to the block and they appeared the same... I haven't actually used this part, as it is still sitting on my self.
Old Nov 14, 2001 | 06:51 AM
delio's Avatar
Tony
For the Oil Press. You will need a 4AN T, and a male to female adapter. You will also want to buy stainless steel line kit that Autometer sells and it comes with all the adapters you need for that aspect of the guage sender hookup. If you have any more ?'s post em and I will try to help. Sorry but I don't have a water temp guage so I am useless there.
Lata Del
Old Nov 14, 2001 | 09:37 AM
Chunger's Avatar
Re: Tony
Lata Del
I think he only wants to T the fitting at the block... so he probably doesn't need -04AN ends... The AUTOMETER electric sender has 1/8" NPT (or 1/4" NPT with the included adaptor) male, which I think is different than the -04AN.
kjlouis
Nov 24, 2018 06:09 AM
maximaham
Aug 20, 2015 10:23 AM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
