Short Throw Shifter -- Need advice
Old Nov 14, 2001 | 10:05 PM
GVW's Avatar
GVW
I am looking for some advice from anyone who has installed a short throw shifter on thier Maxima. I have a 97 SE and am considering it. Did you like it? What changes did you notice? What brand did you use?
Thanks,
Gary
Old Nov 14, 2001 | 10:22 PM
CKNY's Avatar
SMC
I got the smc sts. It's awesome, I love the looks and the shorter throws. It's wayyyy notchier but i like it. Installation was easy but hard. Let me explain. The installation itself is easy. It was almost impossible for me because on my 5 year old car the exhaust bolts are rusted solid. I actually left the cat on and worked around it... which resulted in my not banging out the heat shield correctly and consequently by sts hits on the heat shield. I plan on ripping the whole heat shield off saturday.
Anyway, long story short (too late!! ) I would choose the smc again in a heartbeat.
Old Nov 15, 2001 | 03:47 AM
Mishmosh's Avatar
Re: Short Throw Shifter -- Need advice
Have 95SE and Pacesetter STS ($70). Definitely sweet. Like CKNY, it is notchier, especially 1st/Rev. Install isn't so bad if you can unbolt the Ypipe-CAT bolts. For a short throw, leave off the heat shield. If you love to drive, this is a great mod... right up there with Y-pipe and my H&R/Koni setup.
Old Nov 15, 2001 | 06:51 AM
dm7297's Avatar
is the sts adjustable? if so where can i get one?
Old Nov 15, 2001 | 07:10 AM
GVW's Avatar
GVW
Check out:
http://www.custommaxima.com/GroupDea...roupDeals.html
Select Performance, then Short Throw Shifter The price is $110, please let me know if anyone has found a better deal.
Old Nov 15, 2001 | 07:59 AM
max7's Avatar
STS is great, when you buy the adjustable one, make don't adjust it to the shortest setting. I did that and put everything back together, and than found out the I couldn't shift my gear. From the lowest setting, go about 1/4 of the way up! Hope this helps, and yeah custommaxima is where I got mine, it is the lowest I found!
Old Nov 15, 2001 | 10:30 AM
SuDZ's Avatar
Go with custom maxima I have seen them installed and people really seem to like it once it is in. I have one too but have to wait for a weekend where i can actually get an hour to install it.
SuDZ
Old Nov 15, 2001 | 01:44 PM
99NosMax's Avatar
just don't get the stealin sts, i got that one & its ok but paid too much. plus it looks just the same as the factory shifter.
Old Nov 15, 2001 | 09:38 PM
DOM's Avatar
DOM
How high is the STS compared to the stock shift. Hopefully the actual stick is a lot lower.
Old Nov 16, 2001 | 05:41 AM
Anachronism's Avatar
On the adjustable STS are hight and throw adjustable separatly, or is it lower = shorter throw? I want to decrease my throw quite a bit, but only lower the shift **** a couple inches, is this possible?
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
atriuum
Sep 28, 2015 01:19 PM
