More handling mods- Polyurethane Bushings
Old Nov 14, 2001 | 10:26 PM
ericdwong's Avatar
Alright this is in the wake of Dave B's post about the end link bushings. Dave got another question for you. I hear that only the top ones can be replaced on the Maxima. Is this so?
Also I did some researching and looks like Energy Suepension makes poly bushings for the control arms as well as the front sway bar. Excellent. This is definately my next project, cause its cheap. Poly sway bar bushings and end links, and poly control arm bushings to complete the picture. This almost makes me wonder if portions of the rear axle can be polyurethaned.
I did a search and came up with this thread http://forums.maxima.org/showthread....thane+bushing. I have not heard of anybody posting results on front sway bar and control arm poly bushings.
Old Nov 15, 2001 | 01:27 AM
got rice?'s Avatar
You can be the Maxima.org test monkey and try them out.
man, this forum is nice @ 4:30 am EST... no server overloads
Old Nov 15, 2001 | 06:35 AM
94Max's Avatar
Do it. It's well worthwhile.
K.
Old Nov 15, 2001 | 07:10 AM
maxima561's Avatar
I got poly bushings for my front sway bar from a local custom suspension shop. They charged me $15 for the 2
Old Nov 15, 2001 | 07:49 AM
njmaxseltd's Avatar
I just put them in my car along with the AGX's. 4 bushings in total, top and bottom. The old ones were definately crushed after only 38,000 miles.
Old Nov 15, 2001 | 07:53 AM
theblue's Avatar
Ok this brings up some questions I have:
I'm about to get and install GC coilovers with AGX. I want to replace as much polyurithane stuff as I can. Please list off all the things I can replace and where I can get them. I think while the car is having the suspension done is the idea time to swap the rest of this stuff out.
thanks in advance
Old Nov 15, 2001 | 11:46 AM
roruiz's Avatar
bushings
I just replaced the bushings in my max a few weeks ago. The rubber ones were pretty bad. I bought the control arm bushings, sway bar, and endlinks. I bought them from suspension.com. For the end-link I bought universal endlink bushings since none are made for the max. I ended up with an extra set because you can't replace the bottom endlink bushing on the maxima. make sure you buy extra grease (they don't include enough with the kit), otherwise the bushings will squeak. As far as the ride, I really can't tell because I installed my eibachs and konis at the same time but I'm sure there is a difference.
Old Nov 15, 2001 | 11:49 AM
theblue's Avatar
how much did you pay?
Old Nov 15, 2001 | 12:20 PM
roruiz's Avatar
Here are the links, they have prices posted.
for control arm and swaybar bushings
www.suspension.com/nissancars.htm
for end-links
www.suspension.com/s.b.bushings.htm
I used part # 9-8105 for the end-links
Old Nov 15, 2001 | 04:48 PM
bsetiawan's Avatar
for end-links
Hello evryone, I've got a 5th gen Maxima. Does anyone have any idea if the bushings for the 4th gen will fit into the 5th gen as well ? Any input is greatly appreciated.
Old Nov 15, 2001 | 07:32 PM
theblue's Avatar
for end-links
do you feel they made a difference over the stock ones?
REDinLV
Aug 15, 2024 12:30 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
