Does the ECU adjust fuel according to the O2 readings? (running rich)
Old Nov 19, 2001 | 07:14 PM
CalsonicSE's Avatar
I just installed a Tomei A/F meter yesterday. It gets its signal from its own 02 sensor that I installed on the y-pipe. My OEM 02's were not touched in any way.
When I'm cruising at a steady speed, A/F reading is stoich (around 14.2:1) - no problems there. However, when I go WOT in first and second gear, the reading is only around 12:1 @ 6500rpm. This seems to be too rich. I wish it was leaner to get more power.
I have a N/A 97 with bolt ons and no fuel system mods and over 75000 miles. I have gotten the MIL for rear 02 sensor NUMEROUS times. However, I just ignore it everytime, reset it, & it hasn't come on for a while. Anyway, could a worn 02 sensor cause the ECU to adjust fuel in any way, thereby making the car run rich? Also, is it possible for the OEM fuel pressure regulator to not work as well, also causing the car to run rich? I dunno...
I also installed a fuel pressure gauge but haven't wired everything yet. I want to see how much fuel I'm getting at WOT.
Old Nov 19, 2001 | 10:03 PM
Nismo87SE's Avatar
Re: Does the ECU adjust fuel according to the O2 readings? (running rich)
Yes the ECU adjust the fuel curve during closed loop operation. However, once it goes into open loop it just uses the fuel curves that were preprogrammed in. If you want to lean out the fuel curve you have 3 alternatives: JWT ECU, G-Force ECU, and Apexi S-AFC. While going leaner might get you a couple horses, bumping the base ignition timing will have far more torque gains. The only way to get that is with an ECU upgrade.
Old Nov 20, 2001 | 09:55 AM
CalsonicSE's Avatar
Thanks. Well everything seems fine when I'm cruising (closed loop). I'm wondering what's the normal A/F ratio for our N/A cars at WOT (open loop). Better rich than lean, I guess...
Old Nov 20, 2001 | 10:08 AM
BriGuyMax's Avatar
it's normal for the car to go full rich at WOT (open loop)...mine does it too...pretty much all production cars go rich on WOT...
Old Nov 20, 2001 | 10:54 AM
1MAX2NV's Avatar
Re: Re: Does the ECU adjust fuel according to the O2 readings? (running rich)
He could adjust the fuel via an adjustable fuel pressure regulator too. Much cheaper than those you mentioned.
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
