check engine light disappeared
Old Nov 19, 2001 | 11:48 PM
NISMO808's Avatar
have any of you guys ever had your check engine lights disappear after awhile.
my check engine light came on awhile back and after a couple days disappeared on its own. I was just wondering if this is normal.
Old Nov 19, 2001 | 11:52 PM
Max4U's Avatar
Happend to me before, but it came back a day later I dont know what causes that
Old Nov 20, 2001 | 04:23 AM
kafene's Avatar
sensor detected something
when on of the many sensors detect something, it'll turn it on. if nothing is done after so many key cycles, it turns off (does not mean the problem is gone, just that the computer figures you don't want to do anything about it)
i believe the key cycle for the max is about 42 to 43 cycles.
kafene.
Old Nov 20, 2001 | 05:44 AM
2DMax's Avatar
After my emissions test, had a check engine light, went away after a couple days ~100 miles. Something about a motion/G-force sensor confused after being on the dyno.
Old Nov 20, 2001 | 06:08 AM
BlancMax's Avatar
happened when I had my 95 SE
My car flooded a couple of times (bad gas), the car started and then died, and my light came on. After a few days it disappeared. I think there is something in the service manual that covers that type of check engine light problem. When I get home I'll check it out and tell you exactly what it says. Hope that helps.
Old Nov 22, 2001 | 12:21 PM
PCGuRu2K's Avatar
Re: happened when I had my 95 SE
I'm having the exact same problem.. Please fill me up on the info when you get it.. Thanks!
Old Nov 22, 2001 | 07:53 PM
Pmp-n8a's Avatar
Re: sensor detected something
kafene.
has to be a bit more than that...if there even is such a thing...I drove around with a CEL for 3 months(only because I knew what the cause was)
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
