whats the most effective way to launch a maxima 5(6)speed?
Old Nov 20, 2001 | 05:55 AM
Rancid90SE's Avatar
i was gettin terrible 60ft times in my 91 5spd,whats the best launching technique?
Old Nov 20, 2001 | 06:18 AM
Sprint's Avatar
with or without keeping your clutch?
Old Nov 20, 2001 | 07:18 AM
BriGuyMax's Avatar
too perserve your trans....mid RPM range slips...wears clutch faster
to preserve your clutch....drops from about three grand...puts un-due stress on trans and differential.
personally a clutch job is MUCH cheaper than a new trans...believe me...I've done BOTH on my maxima...
Old Nov 20, 2001 | 07:43 AM
mb1's Avatar
mb1
While we're on this subject(again), I am going to ask(again): How do I engage first gear properly with out hurting the trans or the clutch?
Old Nov 20, 2001 | 07:52 AM
Stereodude's Avatar
You're going to "hurt" the clutch. It's inevitable. You just can't get around it. It's just how fast you hurt it. The clutch wears. That's just a fact of life. I've typically on my other cars, slipped the clutch without giving it gas. Once the car starts to move some I give it a little gas and release the clutch all at the same time. Usually I have the clutch out by the time the car passes 1500rpm. I also don't hold the car on a hill with the clutch. That combination is about as little wear as you can put on the clutch without slamming the tranny.
Old Nov 21, 2001 | 08:51 PM
Rancid90SE's Avatar
i honestly dont care what happens to this clutch,the faster i burn it up,the better,want an ACT anyway
Old Nov 21, 2001 | 08:54 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Stupid FWD
Imagine if the Maxima was awd or Rwd...it would own everyone.
Old Nov 21, 2001 | 10:32 PM
Nealoc187's Avatar
SLOW
I've gotten my best and most consistent 60's with a 2500RPM clutch slip.
Old Nov 21, 2001 | 11:12 PM
PhatGuy
Originally posted by Craig Mack
Stupid FWD
G35 my friend! Soon enough!
Old Nov 22, 2001 | 08:06 AM
Dave B's Avatar
Not DAVEB the parts guy
4000-4400 slight clutch slip and then release the clutch quickly while feeding it gas. I don't slip the clutch for any longer than a second. Wind up the rpms to 4000 or so, slowly release the clutch while keeping right foot at the same position on the gas pedal. Once you start rolling, feed it a little more and release the clutch quickly. DO NOT "DUMP" THE CLUTCH. All you will get is a ton a wheel spin. The goal is to NEVER let you rpms drop below 3000 once the clutch becomes engaged.
Dave
maxima-junky
Oct 21, 2015 05:17 PM
schmellyfart
Sep 25, 2015 04:47 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
