what is the purpose of the plate on.....
Old Apr 26, 2009 | 11:18 AM
panda_1's Avatar
the bottom of the motor where it meets the tranny bell housing? when removed it lets you peer into the tranny case and see the flywheel. if this here just to keep dirt and crap out or what? mine has been missing for as long as i can remember and i finally now have time to try to research if its worth replacing or not, i found what i think the part number is on courtesy nissans sight but need to confirm before purchase.
http://www.courtesyparts.com/11251n-...957_1958_1961&
Old Apr 26, 2009 | 12:49 PM
twiggy144's Avatar
It enables wedging a tool beetween the flywheel teeth to keep the crank immobilized when you need to service other parts, like removing the crank bolt.
Old Apr 26, 2009 | 01:24 PM
panda_1's Avatar
then im assuming it should be replaced and not open to the outside elements. also the link i put in above to courtesy that is the link to the proper cover, correct? i want to order one but also want to make sure its the right one.
Old Apr 26, 2009 | 05:31 PM
twiggy144's Avatar
I cant see the pic in the link
Old Apr 28, 2009 | 01:52 PM
panda_1's Avatar
umm click the link and then the part description and it'll bring up the nisean illustration that resembles FAST
Old Apr 29, 2009 | 09:03 AM
twiggy144's Avatar
From the schematic, what is the part number you are refering to ?
None of the parts look like what I am thinking about, the bell housing is not shown.
Old May 1, 2009 | 12:27 AM
panda_1's Avatar
sorry im taking so long to respond.... but i think its part number 11251n on the schematic
Old May 1, 2009 | 06:53 AM
twiggy144's Avatar
No that does not look like what I had in mind
Old May 3, 2009 | 09:23 PM
panda_1's Avatar
well even under the description it sounds like its the right one, and even the location in the schematic seems to match...
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
