Proper use of dry gas
Old Nov 24, 2001 | 04:01 PM
NickStam's Avatar
Is it supposed to be used as a preventative measure, or only used if you detect a problem? I assumed it was to be used as preventative maintenance in the winter months.
Old Nov 24, 2001 | 04:07 PM
Sonic's Avatar
I wouldn't use it, it really never gets cold enough around here to freeze gas.
Old Nov 24, 2001 | 04:18 PM
NickStam's Avatar
Does moisture only develop if the gas actaully freezes?
Old Nov 24, 2001 | 04:20 PM
Sprint's Avatar
I have used it when my 89 Accord use to stall alot.. it would fix the problem.. what use to happen is when i hit the clutch the rpm's would drop and the car would stall
Old Nov 24, 2001 | 04:22 PM
NickStam's Avatar
only when it got really cold?
Sonic's Avatar
The best preventive measure is to keep the tank above 1/2 full, no need for dry gas in that situation then.
Old Nov 24, 2001 | 04:24 PM
Sprint's Avatar
no.. it did it intermittently.. i think something was bad with the fuel line.. and the dry gas fixed it for a while..
Old Nov 24, 2001 | 04:27 PM
Sonic's Avatar
The problem is that nothing short of dropping the tank and emptying it will get rid of moisture, dry gas does not displace it.
Old Nov 24, 2001 | 04:53 PM
iwannabmw's Avatar
I have never needed it in MA in the Max, but I have in an old Honda I had. The Honda would run rough and hesitate without it. I wouldn't bother with it in CT unless you have drivability problems.
mpbclutch33
Dec 26, 2015 11:11 AM
ef9
Oct 4, 2015 08:43 AM
