QUESTION - Idle is dipping RPM
Old Nov 27, 2001 | 10:01 PM
Nismo's Avatar
I have a 97, when its at idle at 700 rpm and I turn off the ac, the rpm dips down to about 500-400 rpm. It sounds like its going to stall but it goes back up to 700 rpm. is this normal for it to dip that low? im not shure if it was always like this but I just recently noticed this.
Old Nov 28, 2001 | 06:54 AM
2ndMAX's Avatar
Let me see if I can help......
First off, I think your idle is too low. With the A/C on it should be a little higher than 700rpm. I haven't run A/C here in NYC in a few months, but I think it should be around 800rpm. Now when you turn the A/C off your normal idle should be about 650-700 rpm. I would check the IACV. (Idle-Air-Control-Valve) This valve tends to go bad over time, I think more like 100K miles. Get yourself a Haynes manual they have a procedure to test the valve, and if necessary a very clear breakdown of how to replace the valve. Bottom line check out your IACV and see if that is at fault. I'd give you more info but I'm at work and dont have my Hanes manual here with me.
Good Luck!
Old Nov 28, 2001 | 08:15 PM
Nismo's Avatar
ok but this only happends when the car is at a stop and the car idles normal when the ac is on but as soon as I turn it off, it drops to about 500 and then goes back to 700. My idle setting is fine but its just that second of it droping as soon as I turn off ac.
Old Nov 28, 2001 | 09:34 PM
Dave Holmes's Avatar
I pretty much have the same problem. Mine will sometimes stay at 500 at a light, without going back up. I've cleaned my throttle body, (it did it before that), K&N air filter, changed plugs, fuel filter, etc... My '96 GXE (RIP) did it too. My current '97 SE has 60,000 miles, and so did the '96. OT, my '96 GXE had a recall for the front and rear oxygen sensors and water seperator (P8152 campaign, according to my dealership). I'm going to see if this may affect '97s tomorrow. Just some info for you.
Dave
Old Nov 28, 2001 | 09:37 PM
Nismo's Avatar
Dave
thanks, be shure to let me know if you find out what causes this
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
adamgalazka
Sep 8, 2015 01:27 PM
slowlifer
Sep 8, 2015 05:53 AM
