So where exactly is the ValveBody harness?....
2 VE's are better than one!
I'm not seein it. By "located on top of the tranny, near the front of the vehicle", does this mean I should be able to see/find it from above the car, like looking down into the engine bay? I see a few different harnesses and stuff, but not anything that looks like the harness in the diagram. Could someone who has done the VB upgrade give me a few tips on locating it?
Not sure if your set set up is the same as the 5th gen but here's a link to the Selonoid TSB. It has some pretty detailed pics of the valve body and it may help. You may also want to try to contact Don if you haven't already.
http://www.punkdork.net/max/tsb039a.pdf
You have to take the air intake assembly off to see it. Technically, you can change out the solenoids without ever taking the harness loose, but you will have to work with the valve body in the air if you do.
It should be underneath the car. If you take a look at figure 1 in the Selonoid TSB you can see a better pic of it. The harness is actually connected to wires that connect to the selonoid if you look at figure 4 in the TSB and the 3rd figure in Don's Webpage directions that show the whole unit.
ok I found it. I took off that metal clip but how does the harness come loose? Right now that's the only thing that's holding my VB in, and it doesnt seem to want to come loose. I certainly dont wanna just pull it loose. How do I disconnect the harness to get the VB out???? Is it just supposed to slide out when I take off the metal clip?
Originally posted by medicsonic
Push it down, it comes loose. Did you loosen the wiring harness inside the engine room though?
Yes you'll need to remove the selonoids and ship the VB to Don. Make sure you wrap it in plastic and bubble wrap before you put it in the box for shipping. This was from an e-mail Don sent me:
The VB is about 16"x9"x4", and weighs around 15 pounds.
Make sure what ever you pack it in is very, very well packed (we use plenty of bubble wrap. PLEASE ENSURE the VB does NOT ship in the box during shipment (this will cause it to tear thru the box). Please drain completely (about 10 minutes) before wrapping in plastic bags. If it leaks, the post office will ship it back to you (or it may tear and damage the VB).
Hope this helps.
Hope this helps.
magiconthetire
10-26-2015 09:03 PM
Kyle Lee Cleveland
09-28-2015 07:58 AM
