Ground Control and KYB-AGX installed
Old Nov 29, 2001 | 02:01 PM
theblue's Avatar
so I got my car back a ealier and I must say that its like driving a whole new car. I have the AGX set to 2 and 4 (50% stiffness) and about a 1" drop. The car rides smooth and controlled and has almost no body roll. I can take corners much faster than before and when I attempted spin out in a parking lot by creating overstear then going to wide open throttle the car just held its line and did an amazing 180 with little traction loss. I can't wait for it to stop raining so that I can really test it. I'll get some pics up once I have a chance to take some.
Old Nov 29, 2001 | 02:05 PM
deezo's Avatar
Cool. Car has been ridin' high too long huh?
Old Nov 29, 2001 | 02:56 PM
Stealth Max's Avatar
Time for Deezo to get a set of AGX for his stock maxima Only thing I hear is good things about those new AGX.
Old Nov 29, 2001 | 04:10 PM
mitch33x's Avatar
the stiffer suspension should improve your 1/4 time
Old Nov 29, 2001 | 04:24 PM
dm7297's Avatar
how much did it cost all toghter ive been thinking about getting them
Old Nov 29, 2001 | 04:29 PM
Synki's Avatar
Aaron finally has lowered the car. Mwuahaha.
Im glad you like the GC's & AGX. Maybe you should tell Ant95se that.
Anyways, the GC's & AGX are great though arent they? Nothing but the best. Beware not to lower it too much, if you do, it is very bouncy. BTW, which springs did you get the for GC's? THe stiffest ones (red spring)?
Old Nov 29, 2001 | 04:55 PM
mzmtg's Avatar
Minister of Silly Walks
Did you set the corner weights? Or did you just lower it till it looked even?
Old Nov 29, 2001 | 07:14 PM
theblue's Avatar
what are corner weights? I just told the place that installed it to drop it one inch below stock.
cost:
install = $165
springs = (used, but never installed, the red ones, shipped) = $320
AGX = $390 (shipped)
total = $875
if I go really low then it will be mostly for show. the more I drive it the more I like it
Old Nov 29, 2001 | 07:20 PM
theblue's Avatar
cost:
install = $165
total = $875
Old Nov 29, 2001 | 08:04 PM
mzmtg's Avatar
Setting up the corner weights is the main advantage of coilovers.
You set each wheel of the car on a scale. Then you tweak each spring so that each wheel caries as close to the same weight as possible. Now obviously your arent going to get 50/50 front/rear in a Maxima. But you can put a weight in the seat to simulate a driver and get 50/50 side to side.
It's the key to ultimate handling.
A pic of an integra on the scales
Old Nov 29, 2001 | 08:48 PM
max'n out's Avatar
I know it can be dun...but how do you tweak the spring to do that???????????
Old Nov 30, 2001 | 05:06 AM
mzmtg's Avatar
Um, with the adjustable spring perches.
Old Nov 30, 2001 | 05:16 AM
Sprint's Avatar
1 inch lowering.. the car is still riding high
Old Nov 30, 2001 | 05:32 AM
deezo's Avatar
Remnember where he lives though. Snow.
Old Nov 30, 2001 | 06:01 AM
Sprint's Avatar
no snow yet.. and he is on stock profile tires
Old Nov 30, 2001 | 06:02 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Ground Control and KYB-AGX installed
sweet! now your car is officially a beast
*DOWN WITHT THE 4X4!*
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Superbform
Aug 11, 2015 08:10 PM
Team STILLEN
Aug 10, 2015 04:29 PM
