Is my clutch starting to go?
Old Sep 17, 2009 | 05:47 PM
viperboy's Avatar
Never kept a car long enough to know the signs, but it feels like the engagement point is moving up and it doesn't seem to be grabbing like it used to. Could it just be the linkage is out of adjustment or something? Thanks
Old Sep 18, 2009 | 07:07 AM
StnBluPearlMax's Avatar
You will definitely know if it starts slipping... clutch slippage feels like you're revving, basically. You'll push in on the gas pedal and the RPMs will go up but the car won't go any faster.
If you're concerned about the symptoms it's experiencing now, take it to a shop or have a car-experienced friend drive it to check it. It's hard to say without driving.
Old Sep 18, 2009 | 08:02 AM
viperboy's Avatar
I know what slipping is. I don't have that symptom. As I said, it feels like it's not grabbing like it used to and the engagement point is moving toward the top of the pedal and I'm not sure what that could be.
Old Sep 18, 2009 | 08:21 AM
MaximA VlaD's Avatar
throw out bearing off alignment, or fork is bent/out of alignment.
Old Sep 18, 2009 | 08:27 AM
viperboy's Avatar
Is that an easy fix or expensive?
Old Sep 18, 2009 | 09:43 AM
nzelinsky's Avatar
if the clutch threshold is moving and not grabbing as good its going for sure
Old Sep 18, 2009 | 11:39 AM
Sorry, I phrased totally wrong. What I should have said is "you'll definitely know the clutch is going IF it starts slipping."
My presumption was, since you stated that you had no experience with clutches going on cars, that you were not familiar with slippage. But whatever...
Old Sep 18, 2009 | 04:06 PM
viperboy's Avatar
Drove back from philly and it is definitely engaging alot later. If I redline it and shift, it grabs and doesn't feel like its slipping, but its not grabbing as fast as it used to.
I'm taking it to the shop tomorrow. Anything that is common on the 5.5 gens in regards to the clutch? A possible cylinder problem maybe? I guess at this point it would be better to post this over in the 5th gen section...
Old Sep 18, 2009 | 07:54 PM
it is not easy, as you have to pull the tranny off the engine and get in to take clutch components out and replace the fork or throw out bearing. look for repair info online.
Old Sep 24, 2009 | 09:46 PM
PulsarGTS's Avatar
How many miles on the car?
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
