Installed Y-pipe, how much of an HP increase can expect?
I had my stillen intake un-installed cause i did not like the power loss at the low end but the y-pipe sounds cool. What the typical HP increase with the y-pipe?
thanks
thanks
Originally posted by Cumalot
15-20 hp I think. That's more of a realistic number. Of course, you will hear people say you should gain about 20-25hp, but that's wishful thinking.
Originally posted by dm7297
isnt the y pipe more for top end too?
Dyno charts of before and after the ypipe show power gains starting from 2000 rpms or lower. The gains are most prominant in the 3000-5000 rpm range (midrange), and actually taper off past that. Not much gain by 6000 or so. I'd consider the ypipe a midrange rpm gainer more than anything. There are no losses at ANY rpm with the ypipe...only gains. Hell, even at idle there are gains. My car would die at 550 rpm before the upgrade. After the ypipe, rpms could dip to 300 or so and the engine would pop back to life. Definitely a plus with a manual tranny.
Which mod provides more low end torque?
Pulleys maybe?
I've heard about the low end torque loss with the stillen intake so I went with a K&N drop-in filter instead. I will get the y-pipe for the midrange power gain but would like some low end power increase.
Re: Which mod provides more low end torque?
Originally posted by jkratzer
Pulleys maybe?
Pulleys maybe?
Originally posted by young1976
Yup, that's why I put my oem pipe back on and now the car just goes without flooring it all the time. BUt I miss the top end acceleration. who knows, maybe I'll switch it back in the summer.
WTF ?
Y-Pipes decrease low end ?? What the heck. It seems 90% of mods take away precious low end. That's what makes a car fun. I thought 2.5" piping in your exhaust wasn't supposed to effect low end and increase mid-high's ??
Sheesh, I hope i'm right. Why pay outta your @ss for a mod that will take away your fun-power.
Re: WTF ?
I don't think you lose on the low end either, the gains are just MUCH higher through middle of the power band. I have to watch how I accelerate in 1st gear to keep from spinning my heavy a$$ MOMO rims. Thats something I've never had to do.
But it did reduce my 1/4 mile from 15.7-16.0 to like 15.3-15.5, but also remember I have a heavier car(with 3/4 tank of gas) and heavy rims. So I would hope to be in the high 14's with my stock rims and an empty tank of gas.
Well guys after having the y-pipe in for a couple weeks, i feel alittle increase in HP but i doesnt feel like a 15-25HP increase. I feels alot less than that but it gives the exhaust a nice growl. What about and underdrive pulley should that increase the HP as well?
thanks
thanks
thanks
thanks
The UDP is a source of much controversy, there is a clan which says it does nothing, and then there is a clan which swears it's worth the money. I'm with the latter group.
Originally posted by Nealoc187
Y-pipe gave me a significant gain. My trap speeds increased from 92.5s for me to 96.4s and .41 seconds was cut off my 1/4 mile. I have only a y-pipe.
Originally posted by medicsonic
The Y-pipe is proven.
With a Y pipe will you actually be able to FEEL the difference besides seeing it on paper ? And i'm glad this wont lag me off the line like the stupid pop. It's oximoron. You pay for something that makes you slower.
I never raced my car before the pop charger, but I thought it felt a little snapier. It might just sound peppier, but I would think it would give more torque than decrease due to that it should create a little more back pressure and less of a vacuum in the intake. I'm probably wrong, but I'm not an engineer or physicist.
According to the FAQ's, the "15-20 HP gain" is from the combination of an aftermarket intake AND the Y-pipe. So, if the y-pipe is being used w.o/ a Pop or CAI, the gains are prolly smaller. I have a CAI, and am awaiting my WSP y-pipe for my 92SE. I'll give my thoughts once that's installed.
Yes, you will definitely feel the power increase from the ypipe. Make sure to reset your ECU after doing the upgrade, and realize that the ECU will take a few days to a week to fully optimize to the new airflow, so wait to pass judgement for a week after install. You will definitely feel the improvement, especially at ~3000-5000 rpms.
I think the intake complements the Y-pipe pretty well...open it up baby!
btw, at what speed does the intake lose its efffects. I've read that at higher-speeds the intake does not work to your advantage as much as teh stock airbox does.
thanks
thanks
Any other aftermarket parts aren't really worth the money unless you like the look or sound. If you have a 95 or 96 max you have to get a JWT ECU. It adds alot of mid range power and the power past the peek doesn't fall off as fast.
I believe the 4th gen max are limited to ~185-~195 hp at the wheels because the intake manifold chokes the engine off at higher rpms. The next mod id try would be a 2k/2k1 manifold swap, that would probably make alot of extra power.
Blade
i believe anywhere from a 15-30 hp increase is bologna
a stock 4th gen stick runs what mid 15"s and say i put a CAI and Ypipe on my VG stick,i should be runnin with him figuratively speaking since i picked up "25 horsepower" ill put one of my nuts on it that you wont see anything better than 12@ wheels with both mods,but what do i really know,i have neither mod,so maybe i should talk after i get em
Yes, you should.
Yes, you should.
look in no way shape or form am i knockin the ypipe and after the intake that will be my next mod,but i dont expect my VG to all of the sudden have so much power and torque that when i gas it,i crack the back of my cranium on the headrest,i really have heard nothing but good things about it but never heard someone sayin they got this much power,all ive heard that the Ypipe w/ CAI provides noticbly increased throttle response and that it definitly is worth the 400 for both mods
Cattman post HP and torque results on their site:
http://www.cattman.com/images/products/dyno_1.jpg
http://www.cattman.com/images/products/dyno_2.jpg
There is no low end losses on their tests.
I would be interested to see if anyone can verify these results.
Guys who say they feel loss of power off the line: I have talked to some people with the Y and they say there is no loss whatsoever or lag. Either you got 3" piping and lost pressure, or the loss just in your head you bishes
The Wizard
24
Oct 1, 2015 08:47 PM
Violator
Sep 9, 2015 10:14 AM
