jumping a car
Old Oct 31, 2009 | 02:32 AM
smai555's Avatar
jumping a car
i was watching motor week and they had a skit on jumping a car
on the good battery
attach the red cable to the pos and the black to the neg
on the dead battery
attach the red cable to the pos and the black to the frame or block BUT NEVER the the neg
they didnt say why but i always have done pos to pos and neg to neg
anyone ever hear of that?
Old Oct 31, 2009 | 05:18 AM
DAlastDON's Avatar
Batteries produce a small amount of hydrogen gas as the liquid inside of them evaporates. Theoretically, if the battery has been sitting there dead for a while then the hydrogen could be dense enough to explode. Since the negative or ground on the dead car is the last to be connected, there is going to be a spark. You don't want that spark to come in contact with hydrogen and go boom.
Before any hydrogen is produced the battery has to have been setting long enough for the liquid inside it to start evaporating. Were talking weeks if not months and not over-night or a weekend. I have always just put it on the negative post of the dead car without thinking. But its a good practice not to because of the possibility of the BOOM.
Old Oct 31, 2009 | 06:23 AM
KRRZ350's Avatar
Actually when the battery recharges hydrogen gas is created. If you've ever had a battery charger fail and stay on.... holy ****! Shop smelled like rotten eggs for a whole day.
Yes, he's right, it's for not wanting the spark to happen near the battery, they tought us this at school as well.
Old Oct 31, 2009 | 04:17 PM
Nelsito65's Avatar
Last connection to body ground or the engine block is the way it's recommended in all the owner's manuals I've come in contact on any car I owned.
Old Nov 2, 2009 | 08:35 PM
hot_wax_tree's Avatar
on the good battery
on the dead battery
The main reason is because the engine block provides a MUCH better ground than the negative terminal. the body is usually a dumb place to put it because it is typically aluminum.
Old Nov 3, 2009 | 12:55 AM
MaximaSpd85's Avatar
unfortunately, ive never had any luck jumping a car the correct way. as soon as i jump it directly on the battery, it starts. dont know y
Old Nov 3, 2009 | 03:47 AM
blktalon456's Avatar
I do cause ur a num num
Old Nov 3, 2009 | 07:00 AM
Flava_24/7's Avatar
Boosted Panda
The body is aluminum?
Old Nov 3, 2009 | 09:09 AM
smai555's Avatar
how would the block provide a better ground then the actual ground?
aluminum?
i think ill take the answer : Actually when the battery recharges hydrogen gas is created.
Old Nov 3, 2009 | 09:49 AM
oops wasnt thinging....you know what i ment.
Old Nov 3, 2009 | 01:40 PM
pavelsmax's Avatar
I'm fairly certain the last two times I jumped a car (my car was the live battery, red top FTW!) I did the opposite of this and connected the black to my block.
What you are saying here is i've been doing it backwards?
Worked both times btw. The explanation I received was to prevent computer damage.... Guess there was a better reason.
Old Nov 4, 2009 | 09:19 PM
asand1's Avatar
I always go pos to pos, neg to neg, hooking up the good battery last. I was taught this at the technical college i went to.
A dead battery could have boiled off enough electrolyte and left hydrogen gas behind that an internal spark would cause the battery to explode. You don't want to stand over a dead battery while making the final connection regardless of whether its on the terminal or block.
My instructor claims to have seen this, and I believe him.
Rapidly discharging batteries make hydrogen as well as charging batteries.
Old Nov 4, 2009 | 09:31 PM
Redmax's Avatar
Redlinemax Owner
right i usually connect the bad battery first and then the good one
Old Nov 6, 2009 | 03:00 PM
rutlean's Avatar
Simple
Red on Red and Black on Black. Let's keep it simple. Electrons aren't magic.
Old Nov 9, 2009 | 11:21 AM
jason3361's Avatar
Good to know , living in canada there always someone looking for a boost in the winter!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
