got the Maxima.org stickers...how do i put em on
Old Dec 3, 2001 | 12:30 PM
Maximan190's Avatar
i got the stickers today and im playin with the thing and i cant figure out how it sticks on the damn window..does it go on the inside, outside? how does it stick on
Old Dec 3, 2001 | 12:35 PM
Jambo's Avatar
Re: got the Maxima.org stickers...how do i put em on
A good "how to" from Shadow and AP Signworks:
1) Remove the backing paper from the decal.
2) Clean the application area thoroughly and make sure it is free of debris. Apply a weak solution of soap and water to the area and carefully place the decal in the desired location. The soap solution applies some movement of the decal before it sticks permanently, so spraying the decal lightly will help placement.
3) Use a credit car or some similar object to push any bubbles toward the outside edges of the decal until it is smooth.
4) Wait for the decal to dry before peeling away the masking material to ensure that it will be permanently attached to the applied surface.
Old Dec 3, 2001 | 12:40 PM
deezo's Avatar
It helps also if the surface is warmed up when you place the decal where you want it. Do this before you pull the tape back.
Old Dec 3, 2001 | 12:42 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Dec 3, 2001 | 12:43 PM
Maximan190's Avatar
ah so the sticker goes on the OUTSIDE of the window?
Old Dec 3, 2001 | 01:04 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
... unless you want to read it from inside your car.
Old Dec 4, 2001 | 02:05 PM
Maximan190's Avatar
Old Dec 4, 2001 | 03:54 PM
Gotrice4's Avatar
you asked...
NewMax03
Oct 7, 2015 08:27 AM
220k+ A32
Sep 23, 2015 03:38 PM
Socalstillen
Sep 20, 2015 11:46 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
2012Maximus
Sep 10, 2015 12:50 AM
