Raising the Max to Clear Snow Tires
Old Jan 13, 2010 | 12:09 PM
jim_arnett's Avatar
I have a 5th gen with Eibach's and Tokico's and am very happy with the car's stance and handling, 'mostly'.
But when we put my higher profile snow tires on, we found that they rub, front and rear. Not a lot; just enough that an extra inch of height would cure.
Is there any place that I can get some of those spring expanders that could be on the car, just for the 2 months of Winter?
Or, does anyone have another idea?
Thanks!
Jim
Old Jan 13, 2010 | 01:08 PM
homeyclaus's Avatar
What about using smaller rims, like original 16" ones?
It sounds like you already bought tires, but if I were to do this, I'd get cheap used 16" OEM mag wheels and put snows on there. Either that or buy them the same size as my summer tires, and use my main wheels.
Old Jan 13, 2010 | 01:49 PM
Rood's Avatar
throw the stock springs on...
or buy different tires/wheels
Old Jan 13, 2010 | 05:27 PM
SteveB123's Avatar
higher profile, less width=same diameter.
205/60-16's X4 on steelies here.
Old Jan 14, 2010 | 12:15 AM
Gemner's Avatar
where are you rubbing on the tire? top or edge/sidewall? and are you on spacers?
Old Jan 14, 2010 | 06:40 AM
njmaxseltd's Avatar
It sounds more like you have the incorrect size tire.
The Tokico / Eibach setup shouldn't cause your tires to rub.
What size wheels / tires are you trying to use?
Old Jan 15, 2010 | 12:22 AM
Gemner's Avatar
if the winter tires are the size he says, they are very similar to stock size. In fact, they would be ever so slightly shorter
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
Hailstatejig
Sep 2, 2015 06:52 AM
