Woohoo! (help needed..please)
Old Nov 7, 2000 | 06:25 PM
Jane97SE's Avatar
Used force to obtain Admin powers
I finally got my BOV back from Stillen..4 months later(minus the spring they said they were changing)
Ok, how do I install a BOV? TIA
Old Nov 7, 2000 | 06:30 PM
My 4DSC
you need to....
(1) get the flange welded to the pipe that goes from the supercharger into your throttlebody...about halfway in between the two.
(2) bolt the BOV to the flange.
(3) hook up the vaccuum line.
Pretty simple, huh?
Old Nov 7, 2000 | 06:33 PM
Chunger's Avatar
My other car is a Hybrid
Straight bolt on?
I assume that it was the same type that you had on there originally. Two bolts and the vacuum line. I could be wrong though.
Old Nov 7, 2000 | 06:39 PM
Jane97SE's Avatar
huh? I thought all I had to do was stick it on and tighten it.. uh-oh...
where would I get a vacuum line?
Thanks for your help
Old Nov 7, 2000 | 06:45 PM
Chunger's Avatar
Which BOV did they send you?
The one the comes with the SC kit or the HKS (IIRC) one?
Either way... they should both have a vacuum line that activates the BOV when you take your foot off the accelerator (creating a vacuum) behind the throttle body.
See bottom of page 6 on your SC instruction sheets
Old Nov 7, 2000 | 07:02 PM
Jane97SE's Avatar
It's a Blitz BOV..
I dunno.. I will try to put it back on tomorrow..I'll come back if I need any help..Thanks
Shoooter_j
23
Sep 19, 2002 09:33 AM
multiplexor
Dec 7, 2001 08:51 AM
