axle seals
Old Dec 12, 2001 | 07:14 PM
SLC I30t's Avatar
axle seals
Are seals a wear and tear part? the seal where my axle enters the tranny is leaking. Would this be considered in the power train warranty? what about CV joints? my boots are good but the joints pop under acceleration... my car has 56000 miles, and is 7 months out of warranty... opinions???
Old Dec 12, 2001 | 07:44 PM
ericdwong's Avatar
Hmmm, this is a tell tale sign of the infamous differential bearing failure case. Check this- get under the car and see if there is any play of the actual axle itself going into the transmission. If it jiggles, chances are you have a toasted differential bearing. But hopefully its just a seal.
Old Dec 12, 2001 | 07:57 PM
SLC I30t's Avatar
play as in lateral movement? left to right? or just jiggle?
Old Dec 12, 2001 | 08:29 PM
ericdwong's Avatar
Jiggle as well as up down, front back. Left and right should not move either, as the driver side is snap ringed in and the passenger side is bolted to a support housing.
Forgot to ask, do you got a stick?
Old Dec 13, 2001 | 02:50 AM
SLC I30t's Avatar
yes sir
Old Dec 13, 2001 | 06:47 AM
ericdwong's Avatar
Uh oh.... well so far you're exhibiting all the signs. around 60,000 miles, leaking axle seals. Does the axles have play? When 60K comes up, I seriously would drain the trans. oil and send it to blackstone labs or even just eye ball it to see if theres metal shard in there. If there is, you know exactly what the problem is.
For more info go to www.motorvate.ca as Frank also had a similar condition, (and me, and others)
Old Dec 13, 2001 | 08:53 AM
iwannabmw's Avatar
If the car is out of warranty, and it is the bearings, I'd start thinking about how much you really like that particular car. It's really expensive to fix.
Old Dec 13, 2001 | 09:31 AM
SLC I30t's Avatar
I called the dealership, they said its under the powertrain warranty. So no worries...WOOO HOOO. I pick up my loaner I35 on monday......
Old Dec 13, 2001 | 11:34 AM
iwannabmw's Avatar
Old Dec 13, 2001 | 03:15 PM
SLC I30t's Avatar
I hope they don't give me any flack over my mods. EEEK, I can see them telling me that my Rims and Rotors are the cause of this since my car has an aftermarket y pipe and Cat.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
