Help with 97 Max
Old Jul 15, 2010 | 06:43 AM
Black96Max's Avatar
Help with 97 Max
Just bought a 97 5 speed maxima from a friend of mine...has 180K on it but is running great and has been well maintained since he bought it with 60K on it...this is going to be my daily driver and my new 370z will be the weekend car...i just need some advice on what i should have checked out and what services should have been done or need to be done....thanks again for all your help
Old Jul 15, 2010 | 06:53 AM
tigersharkdude's Avatar
this def. should have went in 4th gen discussion not general maxima discussion
EDIT:: you would get a lot more help there, not a lot of posts are made in general discussion
Old Jul 15, 2010 | 07:08 AM
njmaxseltd's Avatar
Look at the maint. records. That should tell you what may or may not be needed. Check the fluids, check the MPG - ENJOY!
Old Jul 15, 2010 | 08:11 AM
cashoit's Avatar
1997 maxi 180k 5sp MT huh
ready, set, here we go......
replace ECTS, PCV, Spark PLugs, Air Filter, Fuel Filter, battery w/ a yellowtop duralast, starter, CPS, CKPS tranny side, brake pads and/or rotor, and KS. Recharge AC. CLean grounds on engine and near wipe fluid neck. Flush and replace tranny fluid and engine coolant. change oil. Clean TB, MAF, and IACV per how tos. Clean EGR if u feelin really ambitious. Clean entire UIM if u feelin super ambitious. Throw some chevron techron in the tank.
afterwards, ur max WILL be good.
Old Jul 15, 2010 | 01:04 PM
Black96Max's Avatar
thanks for all the info guys...i did post in 4th gen and got no responses...
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
magiconthetire
Oct 26, 2015 09:03 PM
