OOPS... I snaped a bolt in the tranny...
I am putting bolts back in my VB and I snapped one of my bolts in the tranny. I am trying to take it out with a screw extractor and a drill. The bolt head is snapped off its just the bolt in the tranny any tips. Thanks
If you can weld...
One of my buddies took his welder and tacked a few tacks on top of one another on a bolt that had the head snapped off of it.
Once he built up enough length, he grabbed hold of it with a vice grips and twisted it free.
I won't be able to use the welder because I don't have one, but will a drill bit do the same job as the screw extractor.
I mean, you could drill it out if you wanted, I suppose. I'd just be wary of stripping out the threads in the tranny. Or drilling in too far.
I'd stick with the screw extractor because they're cone-shaped, whereas the drill isn't, so it won't catch inside the screw and pull it out when you reverse it. Just IMO.
I tried drilling the screw out for about an 1hr or 2 but still the success was very small and I my whole arms were aching from all of that hard drilling and constant pressure that I was applying and I have the black&deckers drill bits if that makes a diffrence.
I'm going to assume you overtorqued the crap out of the bolt. I suggest using a torque wrench to avoid this kind of problem next time.
Is the trans still in the car or out of the car?
If its out of the car, I'd take it to a repair shop or machine shop and have them get it out unless you dont mind drilling a little longer
Just an Idea,
Good luck, if not I'd say take it to a shop.
-DC
I am wondering If It makes a difference in how I am drilling the screw extractor forward/Reverse. I am looking at the directions on my black&deckers screw extractor and It's showing that I should drill it in forward than remove the drill from the screw and take a vise grip and spin it in reverse counter-clockwise.
Any thoughts. Thanks.
litch
123
01-04-2024 07:01 PM
knight_yyz
11-01-2015 01:34 PM
RealityCheck
10-02-2015 06:34 PM
