For those who bought the Cattman Poly. Motormounts....
Old Dec 16, 2001 | 09:13 AM
The New CLIMAX's Avatar
Did you notice much a difference in wheel hop.
At aprox what mileage did you change them at?
Any negative effects to the morotmounts, I heard that sometimes there is more cabin vibration or noise is this true?
In your opinion was it worth it. Thanks
Old Dec 16, 2001 | 09:33 AM
ericdwong's Avatar
Re: For those who bought the Cattman Poly. Motormounts....
Stopped the engine from moving, but probably becaues of the Quaife differential I still have wheel hop. This is mostly because of my stock suspension that still has play. If I dropped the car it would disappear.
There is more noise and vibration in the cabin of the car. Whether this bothers you or not depends on you. You can combat the noise by turning up the idle. Clutch chatter is even more pronounced.
Old Dec 16, 2001 | 12:52 PM
BriGuyMax's Avatar
I noticed a SIGNIFICANT reduction in wheel hop...to almost none. I now have the mounts out of my car and am selling them for financial reasons (I had to pay to get my tranny re-built). With the mounts out of my car now, I really notice how much they did for me...I get wheel hop on my launch AND on my 1-2 shift.
Vibration is more pronounced just like Eric said.
If anyone is interested in this mounts..drop me a line...they were only on my car for approx 2K miles...and are nicely broken in so they vibrate less.
Old Dec 16, 2001 | 01:12 PM
bullseye's Avatar
I have the Cattman/Place poly motor mounts, Quaife ATB differential, Stillen aluminum flywheel, JWT Stage 2 clutch, Unorthodox Racing UDP, Stillen FSTB, Suspension Technique springs, Tokico struts, O-Z Racing Monte Carlo 16x7.5 rims, Michelin Pilot XGT-Z4 225/50/16 tires. When I race, I use Kosei K-1 15x6 wheels and BFG Drag Radial 205/50 tires up front.
Wheel hop? I don't got no stinking wheel hop!
Traction? I got loads of traction... and a drenched cupholder.
Cornering? It can make a U-turn inside a virgin quail.
Vibration? Yes, it's noticeable, but not bad. If women like Harleys, they're gonna love these motor mounts...
Noise? Some, but don't adjust idle speed. Adjust stereo volume.
Clutch chatter? What's that gotta do with motor mounts? My clutch only chatters when I goof-up my footwork.
The motor mount installation was OK. It didn't line up perfectly, but a little "persuasion" was all it took to overcome that.
Worth it? By itself, I don't know. As part of an integrated approach to improving front wheel traction? My opinion: You gotta have it.
Have fun.
Old Dec 16, 2001 | 01:37 PM
Pmp-n8a's Avatar
does this help with torque drive at all???
Old Dec 16, 2001 | 03:14 PM
Xtreme5053's Avatar
that's so funny! especially the quail one! I'm working from the top down: FSTB, RSTB, RSB first, later coilovers, then WSP sub-frame stuff.
Old Dec 16, 2001 | 03:20 PM
bullseye's Avatar
Don't forget [lighter] wheels and [lower-profile] tires in there somewhere, probably before the coil-overs. Good luck.
Old Dec 16, 2001 | 03:29 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
if they get rid of wheel hop and will fit a 2k2 i MIGHT be insteresed. but won't they make the car feel rougher though. decisions, decisions.
Old Dec 17, 2001 | 01:07 AM
BriGuyMax's Avatar
as long as they didn't change the engine mount positions on the 2K2 they should work....they will make your car a little rougher though...
Old Dec 17, 2001 | 01:47 AM
chinaonnitrous1's Avatar
aw man..what is up with the wheel hop on my 2002...geez..its like basketballs sometimes... im thinking its part my fault on my launches...too much gas..but i not exactly sure...but i can lay down a nice strip of rubber =)
Old Dec 17, 2001 | 02:45 PM
hmm i don't know. i like how smooth it is.
Old Dec 17, 2001 | 03:43 PM
BriGuyMax's Avatar
ok grandma
Old Dec 17, 2001 | 03:47 PM
ok grandma
ya disconnect your bottle and we'll see who the granny shifter is. anytime any place.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 20, 2015 11:46 PM
Chaka
Sep 17, 2015 09:53 AM
Violator
Sep 9, 2015 10:14 AM
Samedi
Sep 3, 2015 01:07 PM
