So I had a dream...(NOS questions)
Old Dec 17, 2001 | 07:36 PM
  #41
Gotrice4's Avatar
Originally posted by SprintMax
no.. because if you think about it.. i hardly use my nitrous and i still use the pump.. it still goes to 50 - 55 PSI at WOT just like the stock pump
Sprint, don't you have a S/C? or was i dreaming
Old Dec 18, 2001 | 05:29 AM
  #42
ejj's Avatar
ejj
Doesn't the stock pump only go to 43PSI at WOT? Wouldn't the extra 7-10PSI cause you to run rich (not that its a real problem)?
Old Dec 18, 2001 | 05:39 AM
  #43
Sprint's Avatar
no the stock fuel pump is designed to go 60 - 65 PSI
Old Dec 18, 2001 | 06:11 AM
  #44
ejj's Avatar
ejj
Right, but in stock form, doesn't it only get to 43PSI at WOT?
Old Dec 18, 2001 | 06:15 AM
  #45
Sprint's Avatar
nope.. 20 PSI car off, 35 PSI idle, 50 PSI WOT
Old Dec 18, 2001 | 06:41 AM
  #46
ejj's Avatar
ejj
http://forums.maxima.org/showthread....ighlight=43PSI
43PSI
Anyways, either way the engine is getting more fuel then before. Any stumbling or anything when running NA?
Old Dec 18, 2001 | 07:02 AM
  #47
Sprint's Avatar
not sure where i got 50 PSI from.. but the FSM says 35 at idle.. 43 ON.. doesn't really say WOT
Old Dec 18, 2001 | 07:10 AM
  #48
Washington DC Maxima's Avatar
Re: So I had a dream...(NOS questions)
I've had that dream..
Now, I never dream, or if I do, I don't remember them. But this weekend I dreamed that I had installed a NOS system in my car, and loved it!
So, most of the day yesterday I rescearched NOS (read almost every thread on here that I could find...and some of those where damn long!) and I have a few questions that I couldn't really find an answer to:
- Is a A/F guage needed? Everyone says yes, but then goes to say that it will not be that accurate.
- EGT guage. Where can I get an Apexi one? Is that the "best"?
- Guys with NOS installed, can you post some pics of your interior setups? I don't mind guages, but I don't want switches everywhere. I was thinking that I would make a custom panel to go inside of the armrest.
- Can you unhook the bottle and take it out, if you're going on a trip or something and need the trunk space.
- How is the bottle mounted? Is it on the wooden floor board in the trunk, or attached to the body (metal) of the car?
- Can you get a guage to indicate the amount of gas left in the tank? I haven't seen anything like this, so I'm assuming no.
That's it for now...I'm sure I'll have more questions in the upcoming months.
Old Dec 18, 2001 | 12:18 PM
  #49
Synki's Avatar
Like Sprint said, the stock FP can hold about 60-65psi.
N/A @ WOT i was around 43psi. I think that is what its suppose to be. Mine is like 48-50 WOT now when im NA b/c of the new fuel pump. My idle is now about 37-39psi. 42-43psi when the car first starts up and is running rich. At a 100 shot i am about 85psi @ WOT.
Old Dec 18, 2001 | 12:23 PM
  #50
Sprint's Avatar
what fuel jet are you using?
Old Dec 18, 2001 | 12:25 PM
  #51
Synki's Avatar
.071 fuel jet. It was one of the part numbers you gave me.
...BTW, Thanks for those numbers.
Old Dec 18, 2001 | 12:26 PM
  #52
Sprint's Avatar
what am i using? i forgot.. i wanted to make sure you and I were on the right jet..
Old Dec 18, 2001 | 12:29 PM
  #53
Synki's Avatar
Didnt you say you were using liek a .06x jet? I might run the next fuel jet down and see what happens...which would the .067?
Old Dec 18, 2001 | 12:44 PM
  #54
Sprint's Avatar
answer your damn AIM window
Old Dec 18, 2001 | 01:55 PM
  #55
ejj's Avatar
ejj
So I can assume that the extra Fuel Pressure while NA isn't a problem?
Old Dec 18, 2001 | 06:17 PM
  #56
Y2KevSE's Avatar
Rice Boy in Denial =)
Hey Sprite... what's that picture for?
You would like me as the FI mod wouldn't you?
I'm learning a lot by reading everyone's nitrous questions/answers.
Old Dec 18, 2001 | 06:20 PM
  #57
Sprint's Avatar
the post ***** alert monitor picked you up a mile away
E.. the pump doesn't affect NA performance.. just the colder plugs you will be running
Old Dec 18, 2001 | 06:44 PM
  #58
ejj's Avatar
ejj
How much? Enough to use the stock plugs if you aren't going to be using the bottle (ie, not at the track)?
Old Dec 18, 2001 | 06:49 PM
  #59
Sprint's Avatar
colder plugs slow me down big time.. well if you don't mind swapping plugs when you want to use your NOS you can have both.. i never know when i am going to run into some prudent ***** who thinks he is fast .. so i have by bottle on and ready at all times thats why i run colder plugs all the time
Old Dec 18, 2001 | 08:28 PM
  #60
Bryan H's Avatar
Sprint. don't make me come find you with my gsx!
hehehe
j/k
p.s. at least someone else is answering nitrous questions now besides me
Old Dec 19, 2001 | 03:02 AM
  #61
Sprint's Avatar
unless you are using Direct Port.. Dry is better than wet if you are only going up to a 100 shot.. Matt explained it before that if your engine backfires when using a Wet System.. bye bye engine
Originally posted by rOaD bEaSt
You better use a wet system ..
You will not need all these things ..
I'm using .055NOS , .043=Fuel maybe I'm running lean a littel but I'm using the NOS at the red line once I bent a vaulve because I missed the shifting I'm using NOS from the second till the 5 with no problem .
Guy I just wanna know something how can I run this jets with stock fuel pump ?
As you know that my engine is compresed so I shouldn't be able to use NOS as much you can ..
When I was using a 100 shot I wasn't having any problems .
I wanna know something I have a video of sx7r racing a 3000 GT did he use the NOS from the first ?
I can't touch the NOS botton at the first at all at all if I do that I will kill my engine I tried many times to do that but I wasn't able to it goed to red line so quick and losing a traction ..
I will show you everything one day but let me get a camera first and I should fill the bottel I will do that just for you guys to show you that everything that I said I was doing in my car ..
Old Dec 19, 2001 | 03:53 AM
  #62
ejj's Avatar
ejj
Yeah, besides, I already agreed to buy a dry kit!
Old Dec 19, 2001 | 05:00 AM
  #63
Synki's Avatar
Woohooo! Another Juice Boi.
Old Dec 19, 2001 | 08:12 AM
  #64
SuDZ's Avatar
Road Beast - Your still running with your stock fuel pump? I thought you were up to a 135 bottle or something nuts like that? How have you been running it stock with that? I know you engine is a bit different but I did not know it could take that much.
SuDZ
Old Dec 19, 2001 | 08:16 AM
  #65
Sprint's Avatar
SuDZ
i think on the wet kit.. it takes fuel from another source or something.. so he is not putting that much load on the stock fuel pump.. so he doesn't have to upgrade his pump.. Matt can explain it better
Old Dec 19, 2001 | 12:17 PM
  #66
SuDZ's Avatar
OPh yeah that right. I forgot he was running a different kit then most. Any idea how much HP you can expect to put on the engine with his setup? Or road beast do you know?
SuDZ
Old Dec 19, 2001 | 12:26 PM
  #67
Sprint's Avatar
SuDZ
well keep in mind .. Road Beast has a 4th gen that puts out 220 hp stock.. as oppose to 190 stock.. so he is already ahead of the game.. he has a JDM engine with stronger parts so he owns us right now..
Road Beast .. a pump is only $119.. should think about it anyway..
Old Dec 19, 2001 | 04:14 PM
  #68
Bryan H's Avatar
me personally, i wouldn't trust a dry kit above 80hp.
if you backfire on a wet kit you won't blow the motor.
i backfired when i had my max, only loosened the valve cover. no big deal
Old Dec 20, 2001 | 12:15 PM
  #69
SuDZ's Avatar
Does NOS increase the chance of backfires? Mine never has but I dont run NOS so curious why this would be a fear? Can we run a wet system on the US version of Maximas?
SuDZ
Old Dec 20, 2001 | 12:34 PM
  #70
Sprint's Avatar
SuDZ
yes
Old Dec 20, 2001 | 01:02 PM
  #71
ejj's Avatar
ejj
yes
Yes to which question, increased chance of Backfires, we can run a wet system, or both?
Old Dec 20, 2001 | 01:12 PM
  #72
Sprint's Avatar
yes to wet
Old Dec 20, 2001 | 01:16 PM
  #73
ejj's Avatar
ejj
yes to wet
Sounds like a moto to live by.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
