Installed UDP and fixed exhaust leak...
Old Dec 17, 2001 | 11:32 AM
redmaxpa007's Avatar
i SeE what you did therE
well the UDP install was realitly easy.. except i unscrewed the smaller pulley tightner screw and i had a hell of a time getting it back in..... then the larger belt tension pulley "bolt" somehow got crossed treaded.. so i had to tighten it the old fashion way... i got a huge screwdriver and pushed... and my bother tightened the pulley.....
can i feel difference?.. yes.. yes i can (so dougy)
i get to 6000 rpm a lot quicker than i did before...the car is more responsive at lower rpms..(which i was hoping for)
the exhaust leak? hmm.. when i got the car on the lift... there was a bolt missing one the cat.. so.. replace the bolt.. make sure everything it tight.. ~~~boom~~~ no more leak!!
i aslo found out why there was a clunking noise from my rear passenger side... the b pipe is touching the underbody when i corner.. so a muffler gromet and a bolt in the right place and that noise will be history...
it was a good weekend!! got all my "problems" fixed!!
Old Dec 17, 2001 | 11:51 AM
Sprint's Avatar
i can say i speak for us all when i say.. No one really cares
Old Dec 17, 2001 | 11:53 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Dec 17, 2001 | 11:58 AM
Sonic's Avatar
Let's see, the car gets to 6000 faster, but I bet your ETs haven't changed. How is that possible then? The best a person has gooten is a .2 second faster time in the 1/4, which IS NOT feelable. How are you feeling it?
Old Dec 17, 2001 | 11:59 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Old Dec 17, 2001 | 12:00 PM
Sprint's Avatar
Originally posted by Chebosto
hello my fine feathered California Friend
Old Dec 17, 2001 | 12:07 PM
BriGuyMax's Avatar
actually .2 seconds is pretty damn good....that's roughly half of what a y-pipe gets you. I ran 2mph faster traps with UDP even with a 30mph headwind and BAD 60 foots...
Old Dec 17, 2001 | 12:08 PM
Sprint's Avatar
I think the reason your buddy with the 2k max is beating you now is that your car has finally adjusted to the UDP take it off and you will beat him once again
Old Dec 17, 2001 | 01:12 PM
Old Dec 17, 2001 | 01:15 PM
look when i finally get to the track, you and i can argue all day on how mods effect the car...
you can't talk... or i will tell everyone why your car was #$%@# in the dyno..at maxus
Old Dec 17, 2001 | 01:18 PM
UMD_MaxSE's Avatar
Got Bent?
cool glad you like the UDP
Old Dec 17, 2001 | 01:22 PM
thank you!!!
Old Dec 17, 2001 | 01:54 PM
maxmizd27's Avatar
Re: Installed UDP and fixed exhaust leak...
What did I tell ya? Thought you'd like it.
Old Dec 17, 2001 | 02:02 PM
SuDZ's Avatar
I Like mine. So I care. What is next on your list of mods if anything?
SuDZ
Old Dec 17, 2001 | 02:11 PM
SuDZ
hmm
rsb...
underbody neons
polished manifold
racing seats
cf hood
dougy tail lights
hmm
what else? i will think of some more
Old Dec 17, 2001 | 02:14 PM
UMD_MaxSE's Avatar
Got Bent?
cool... so you decided no altezzas?
Old Dec 17, 2001 | 02:20 PM
yes.. NO ALTEZZAs
Old Dec 17, 2001 | 04:49 PM
UMD_MaxSE's Avatar
Got Bent?
yes.. NO ALTEZZAs
Old Dec 17, 2001 | 05:21 PM
BriGuyMax's Avatar
that's funny....becuase the night BEFORE he beat me...I beat him....It was a loose air intake, dragging brakes, and loose spark plugs that was messing up my car.
Old Dec 17, 2001 | 05:52 PM
yourmove's Avatar
Redmax.....Could you give me more details on the quick fix for your rapping B-pipe? Mine started this when I added a y-pipe and rt cat to cat back. Thanks.
Old Dec 17, 2001 | 06:41 PM
well, i looked under the car and the last bend on the b-pipe was where the clunking noise is coming from. that is where the muffler and b-pipe connects just move the pipe around some.. it was appent mine was clunking.. i pushed it and i clunked..
the quick fix is---the rubber gromet thing (muffler hanger)secure one right on the place were the pipe touches. they are made for heat. so you will not melt it. they are only like $3
Old Dec 17, 2001 | 06:51 PM
yourmove's Avatar
Yes, mine hits at the same location. So, you just let it hit the gromet rather than the under body.....Right?
Old Dec 17, 2001 | 07:02 PM
yeppers
that is what i am saying
Old Dec 17, 2001 | 07:08 PM
yourmove's Avatar
yeppers
Ok, cool! Don't you think that your exhaust is kinda sloppy with the oem hangers? My exhaust has quite a bit of lateral movement.
Old Dec 17, 2001 | 07:16 PM
the lateral movement is terrible....
they forgot to add one more hanger.... that would have stiffened it up enough..
Old Dec 17, 2001 | 07:18 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
don't tell eric wong that he'll start another thread about that is why his tranny is broke
Old Dec 17, 2001 | 07:26 PM
yourmove's Avatar
Yep! The (easy) options are to weld a rod to the body and exhaust or polyethelene bushings etc.....It's all hackery! I know, yo its ok and rba did something with some custom hangers at $15 a piece (pricey) but I would like to do something clean and tight.
Old Dec 17, 2001 | 07:29 PM
ya they were poly hangers and i have been waiting for mine forever.
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
