HELP! Battery Voltage LOW!
Old Dec 9, 2010 | 09:42 PM
NJ3ndri's Avatar
So i was tearing on this. its a 95 3.5 swap. battery was running at 14 then all of a sudden dropped to 11.8 lights dimmed. the battery light isnt on or anything. belt is still there . i hope it isnt an alternator -_-. if it is i got an 06 3.5 if anyones selling an alternator
Old Dec 10, 2010 | 06:43 AM
njmaxseltd's Avatar
Sounds like you lost the alty output, but battery and brake light should be on???
Check the connections at the alty.
Have the alty tested at Autozone.
Old Dec 10, 2010 | 07:42 AM
NJ3ndri's Avatar
yea i lost the alt once and those lights would start coming on. thats why i have a feeling its the battery. besides i havent clamped it down so it mustve been going crazy with all the bumps i hit. it seems as if it lost its charging ability and the car is barely working off the alternator
Old Dec 10, 2010 | 08:46 AM
ghostrider17's Avatar
I had similar issues with my 4yr old batt. a few months ago.
i KNEW it was on it's way out, and didn't want to "nurse" it thru another winter.
I went to Autozone and got their top of the line GOLD whatever batt. and called it a day. (highly rated batt., btw).
The battery continued to "test" okay, even after i yanked it from the car....but again -- I KNEW it didn't have much left in it.
Good insurance, and piece of mind.
Good luck with yours.
gr
Old Dec 10, 2010 | 11:21 AM
asand1's Avatar
Check all your connections at the battery. Battery moving around can loosen connections. Check fuse for the alt charge wire.
Old Dec 10, 2010 | 02:52 PM
NJ3ndri's Avatar
gr
yea idk how old this bat is but im gonna use another (known good) one i got at home so ill find out monday if that is the issue
Old Dec 10, 2010 | 02:54 PM
NJ3ndri's Avatar
youre talking about the fuse thats by the + terminal right? i dont think this one has a fuse there. thats the first thing i looked for. im gonna clean the terminals and all that then try again.
Old Dec 11, 2010 | 03:12 PM
asand1's Avatar
Check the 140A fuse and the connections at the bat positive.
Old Dec 12, 2010 | 10:15 AM
NJ3ndri's Avatar
PROBLEM SOLVEDD PROBLEM SOLVED.!!
The connector at the alternator has 2 wires. one of them snapped (causing an open). maybe from the jerking of the engine? but it was the white/red wire which im guessing was sort of like a signal or something to the alternator. soon as i touched them together the voltage started rising back up. it was a pain to just pull the connector out. but from there on wasnt bad. connector was pretty easy to take apart
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
