Lower rad Crossmember rust FIX
Old Dec 19, 2010 | 06:07 PM
NJ3ndri's Avatar
So i fixed that lower rad rust problem today. and ill be putting up some pics soon of it and if anyone needs this work done let me know
If you have trouble seeing the pictures. hold Ctrl on your keyboard and use the scroller on the mouse to adjust the screen size
Old Dec 21, 2010 | 05:53 AM
djfrestyl's Avatar
Suspension Yoda
Good to know! I know someone that is interested, will forward this thread to them
Old Dec 22, 2010 | 02:45 PM
NJ3ndri's Avatar
cool thanks
Old Dec 22, 2010 | 03:03 PM
KRRZ350's Avatar
Good job, looks nice & I'm def impressed. I also fix a bunch of these for $450 out the door but with a new oem support, yours can be fixed that way but just a heads up not all of them can, I have done several that were much worse, I'm talking broken into three pieces & rotted the tabs off for the radiator so it was being held by the hoses and usually some sort of zip-tye etc to the upper support.
Old Dec 22, 2010 | 10:33 PM
NJ3ndri's Avatar
i know what you mean ive seen some. one of my friends from boston (alot of salty roads) has an i30 thats completley rotted. the hood cant even stay shut anymore. i was going to replace the whole rad support for him but didnt really have much time to do it. the one from the pic is actually my first fix up i did with a friend. i didnt really approach it the way i wanted to and came up with some better and cleaner ideas after i was done. i might eventually have to redo it but it doesnt seem to be having any problems. i have a 3.5 swapped 4th gen and i give it a little bit of gas here and there, so if its gonna break i wanna know what the breaking point is. so far nothing
Old Dec 22, 2010 | 10:37 PM
NJ3ndri's Avatar
nissan wanted 139 i think for the lower rad support (OEM) on courtesyparts.com . i was on a little bit of tight budget and only spent about 15 bucks tops on the angled iron.(which im not going to use anymore seeing as to how my welder cant really penetrate it too good). i use a mig and not a tig. so for the next fix ill be using steel instead of iron
Old Apr 13, 2011 | 10:25 PM
anjy834u's Avatar
very impressive. no doubts about it.
Old Apr 22, 2011 | 04:15 PM
F35-JSF's Avatar
Man mine looks just like the first pic. It's about 450 to fix?
Old Apr 22, 2011 | 07:42 PM
samalet's Avatar
Pretty good. we just got a replacement from rockauto. Probably will rust through in a year or two..
Old Apr 22, 2011 | 07:43 PM
NJ3ndri's Avatar
yea this cost abt 20 bucks + a headache to fix. lol
Old Apr 24, 2011 | 09:13 AM
F35-JSF's Avatar
Man wish I knew welding work. Going to take it to the bodyshop.
Old May 6, 2011 | 10:42 AM
Dhione's Avatar
good stuff man. wish I saw this before I got mine replaced at a body shop
Old May 6, 2011 | 09:17 PM
F35-JSF's Avatar
How much was it?
Old May 8, 2011 | 07:47 AM
djfrestyl's Avatar
Suspension Yoda
Just replaced one yesterday. The job wasn't awful but make sure you have a lot of good sharp titanium drill bits on hand.
Old May 12, 2011 | 08:22 PM
T_Behr904's Avatar
My 2000 looks the same way. I'm assuming that's why I'm getting excessive engine movement since the front mount attaches to the rear of the lower crossmember and is flexing under load. Gotta get it replaced asap....
Old May 13, 2011 | 09:40 AM
ajm8127's Avatar
Definately. I replaced my lower support last weekend with the OEM part from Courtesy and I can say without reservation that my engine is a lot more solid now.
Old May 13, 2011 | 05:52 PM
T_Behr904's Avatar
How much does Courtesy want for them? About how difficult and how much time did it take you to do it? The dealership I work at is opening up a new bodyshop so I can get it done for a good deal if it looks like it's going to be too much for me to do.
Old May 13, 2011 | 06:48 PM
NJ3ndri's Avatar
i think its like 130. its really not that hard
Old May 14, 2011 | 09:59 PM
djfrestyl's Avatar
Suspension Yoda
Not difficult. Time consuming, and proper tools required. I lost 3 drillbits when I just did one.
Old May 15, 2011 | 09:00 AM
NJ3ndri's Avatar
you use a drill bit and another bit that cuts out the top part of the pinch weld. idk what its called
Old May 15, 2011 | 09:35 AM
KRRZ350's Avatar
^^ Spot weld cutter
Harbor freight has a cheap one that works great!
Old May 15, 2011 | 09:51 AM
NJ3ndri's Avatar
there you go. of course when you replace this you have to remove the bumper condenser rad and everything out of your way
Old May 15, 2011 | 07:53 PM
djfrestyl's Avatar
Suspension Yoda
Ah. I just used regular titanium bits for a pilot hole, then my titanium unibit to bore out the hole until it was bigger than the weld. Also worked fine.
Ya, most of the front end had to be removed. Condenser had to be moved out of the way a bit, not necessarily removed.
Old May 15, 2011 | 11:23 PM
cloverhsu7's Avatar
If one day I need this work done, I'll contact you. haha
Old May 24, 2011 | 09:59 AM
MatMax01's Avatar
This will be project number two. I have to get the radiator replaced and get her back on the road then got to all the body shops in the area and see what it will cost me. My guess is any where from $ 700 to $1000. The support is the most important part of the car. Holding the front and rear engine mounts and that is where I jack the car up at. the last oil change it was making crushing sounds.
Old May 24, 2011 | 09:10 PM
NJ3ndri's Avatar
damn thats o.d lol. ill do it cheaper lol.
Old Aug 20, 2011 | 10:13 AM
johnmax98's Avatar
Very interesting because I have the same problem....I didn't think it was that bad, but I looked today and it seems the member is separated from the lower support. You really have to look very closely to realize that...ouch!
Old Aug 20, 2011 | 10:36 AM
QT1 5MT AE's Avatar
Gram Lights addict
thank god for i live in the west coast, LOL
Old Aug 25, 2011 | 12:12 PM
Montego Murph's Avatar
Does one have to be able to weld to do this job, or is it a nut-and-bolt replacement?
Old Aug 25, 2011 | 12:28 PM
djfrestyl's Avatar
Suspension Yoda
The existing one is spot welded on. Plenty of members have replaced it and allowed the bolts to hold it in - it's pretty damn sturdy this way, but still not to OEM spec. Personal preference, really.
Old Aug 29, 2011 | 03:47 PM
NJ3ndri's Avatar
you could probably do it that way but you would need to do alot of fabrication just to bolt up your new support to the existing rad support. easier welding if you ask me
Old Aug 29, 2011 | 04:23 PM
djfrestyl's Avatar
Suspension Yoda
^^ I think he's referring to the situation in which the old one is completely removed. That's how I responded in the above post at least...
Old Sep 5, 2011 | 11:41 PM
Mr. Blue Sky's Avatar
nice cost effective fix for this problem. Did you coat it(paint it) with some sort of durable rust proof coating? or at least an underbody coating?
Old Sep 7, 2011 | 06:16 PM
NJ3ndri's Avatar
deff. lol i dont want to see that hole ever again lol
Old Sep 13, 2011 | 05:30 PM
G3Nis's Avatar
What kind of steel was that and did you get two 90 degree corner pieces and weld them up?
Old Sep 13, 2011 | 07:17 PM
NJ3ndri's Avatar
i used angled iron. i just bought 3ft of the 90 degree one and cut it up. also used some regular sheet metal i had laying around
Old Sep 14, 2011 | 05:29 AM
nissandrvr98's Avatar
good now do mine
Old Sep 14, 2011 | 06:22 AM
djfrestyl's Avatar
Suspension Yoda
^^ This is not a difficult job. You need some good drill bits, some basic tools, and a few hours of time.
Old Sep 14, 2011 | 01:40 PM
G3Nis's Avatar
Would a home depot/lowes have this or did you got to a metal shop somewhere? how thick was it, 1/8"?
Old Sep 15, 2011 | 03:57 PM
NJ3ndri's Avatar
not difficult at all. just time consuming. and yes i bought this at lowes. home depot should have it too. but i recommend steel instead of iron. it took alot to get this thing to weld
captchaos
Mar 15, 2016 12:18 PM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Starrider
Dec 18, 2015 04:43 AM
Violator
Sep 9, 2015 10:14 AM
sdotcarter
Sep 2, 2015 09:53 PM
