Doing my "every 30k." Apexi air filters? Transaxle fluid & coolant recommendations?
Old Dec 20, 2010 | 12:22 AM
DanMaxima's Avatar
I'm looking at doing my "every 30k" work myself for the first time for my faithful, bone-stock, 4th gen max (98 SE automatic).
  • Air Filter. I'm Just curious -- How much better is the Apexi air filter over, say, a Purolator filter? I've decided to not go the K&N lifetime filter route. The oil vs mass airflow sensor is a problem I'd like to avoid for now.
  • Automatic transaxle fluid. Any recommendations?
  • Coolant. I'm assuming coolant is cooltant, nothing to get picky about?
  • Fuel Filter. Any recommendations? This I may have done professionally.
No problems right now, thought I do have "that sound" when I turn the wheels full lock. I guess it could be referred to as a moan. Right now my ignoramus approach is to simply avoid turning that tight.
Old Dec 20, 2010 | 06:59 AM
njmaxseltd's Avatar
Pick up a FRAM air filter at Walmart for 4 bucks.
AMSOIL makes fantastic automatic tranny fluid, I've been running it for years.
Coolant, use the pre mix, I like Prestone
Fuel Filter - Nappa, Autozone, hell maybe even Walmart.
Old Dec 25, 2010 | 11:07 AM
DanMaxima's Avatar
Thanks for the recommendations. Any from others?
Merry Christmas to all here.
Old Dec 26, 2010 | 09:06 AM
BenStoked's Avatar
Jesus was a Zombie.
http://mkiv.com/techarticles/filters_test/2/index.html
yes, it's for a supra, but it's an interesting read.
amsoil, royal purple, any real brand of lubricants should have a great result.
don't go cheap, and don't use tap water. prestone 50/50 is available anywhere (or prestone 100%, and distilled water). don't use straight antifreeze.
so far, nobody has shown a significant difference in fuel filters. as long as it catches the crusties that get pas the fuel pump sock, it will be fine.
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
sdotcarter
Sep 2, 2015 09:53 PM
