I nee a 6th gear!!
Old Jan 25, 2011 | 09:36 PM
NJ3ndri's Avatar
I nee a 6th gear!!
4th gen 3.5 swap. 5 speed trans.
redlined 5th gear with plenty more to go at id say abt 147mph.( at a closed course)
anyone know if the 6 speed trans is any good for this swap on low end? i mean at least ill have another gear to go for top end but hows the lower gears?
anyone got this on their 4th gen and wanna share likes and dislikes?
Old Jan 26, 2011 | 04:23 PM
jasoneon's Avatar
I've got an 05 6 speed. It's geared with the ratios very close together. A lot of the time I take off in 1st, shift to 3rd and then go into 6th. In 6th gear at 70 mph it runs 2,500 rpm. I wish it was geared a little taller and ran about 2,200 or less on the interstate to help mpg. Here's an idea *roughly* of what speed each gear will get you at redline 6,600 rpm.
1st 38mph
2nd 62mph
3rd 90mph
4th 115mph
5th 145mph
6th 185mph <---theoretically
Old Jan 26, 2011 | 04:35 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/3261761-post2.html
Of course that is theoretically on unloaded tires, and tires vary, even if the same size. I have a spreadsheet if you're interested.
It will let you dial in tire sizes and new rev limits etc.
Also,
http://forums.maxima.org/4928019-post1.html
And these are the A33B ratios:
http://forums.maxima.org/4552646-post20.html
Old Jan 26, 2011 | 08:58 PM
NJ3ndri's Avatar
nice. thanks guys thats what i needed
Old Jan 27, 2011 | 07:12 PM
vernk's Avatar
irrc the early years of the altima 3.5 had taller gearing.
Old Jan 27, 2011 | 08:47 PM
NJ3ndri's Avatar
the 5-spds right?
idk but this thing gets up to speed pretty quick i floor it next thing i know im at 110..120..130..140. its quick n all but its limited. i wouldnt mind if it was 110..140. lol thats a whole "nother" story tho and thats just not happening
Old Jan 27, 2011 | 09:17 PM
jasoneon's Avatar
A little further analysis shows that
Here's some interesting data I got.
MPH @ at 6500 redline
--------5A---5M----6M----4A
1st ----44----40-----41----47
2nd ---67----70-----67----85
3rd ---103--102-----94---132
4th----152--137----124---190
5th----201--164----164
6th-------------------208
RPM @ 75 mph cruising
4A--------2562
5A--------2420
5M--------2961
6M--------2340
Where did this info come from exactly? There's no way my 6 speed will hit those speeds in any of those gears. Also at 75mph I'm running over 2,600 rpm and not the 2340 like the chart above says. Did they make different final drive ratios in the 6 speeds? It's like my car has a numerically higher ratio than the above chart.
Old Jan 28, 2011 | 02:01 AM
Hectic's Avatar
Hey I got an uncle Louie from Parsippany!
Old Jan 28, 2011 | 10:32 AM
NJ3ndri's Avatar
4A--------2562
5A--------2420
5M--------2961
6M--------2340
yea i was wondering the same
i might know him. lol prob not but who knows
Old Jan 28, 2011 | 10:41 AM
NmexMAX's Avatar
dot dot dot ...
Spreadsheet using OEM tire sizes and OEM gear ratios. Also, our tachs are calibrated by kindergartners, and our speedometers will be off with respect to the tires being used (irrelevant unless using a secondary MPH indicator other than the speedo). So those wont be right on, there's a lot of room for error.
I do actually have a 6MT dyno showing very close numbers to those using Dynojet software on top of 3rd and I believe 4th.
Just an FYI, the speed calculator that Nealoc provided is nearly dead on to mine re: the 5MT gears.
Instead of me trying to do all the work, why not go here: http://www.vibratesoftware.com/html_...nsmissions.htm
And here: http://www.vibratesoftware.com/html_...rive_axles.htm
And then here: http://fatboyraceworks.com/gears/ind...raph&Compare=1
Old Jan 28, 2011 | 03:07 PM
aackshun's Avatar
I'll be 6mt soon (taking the car apart Sunday)... But i'll be using 4.1 gear ratios (04+ 6mt), I'll report results in the 4g section.
Old Jan 28, 2011 | 04:24 PM
vernk's Avatar
Originally Posted by NJ3ndri
the 5-spds right?
RS5F51A (VQ35DE Engine - 2002-2006)
3.812
http://www.vibratesoftware.com/html_...les.htm#Altima
that might help you a bit
Old Jan 28, 2011 | 04:27 PM
vernk's Avatar
but it does seem that the 2.5 model has the same 6sp as the 3.5 but with taller gearing, both are RS6F52A
Old Jan 28, 2011 | 06:06 PM
jasoneon's Avatar
After an hour of digging around I figured out why our rpm/speeds don't match up. In 6 speed Maximas,
02-03 final drive is 3.812
04-06 final drive is 4.133
All of the gear ratios are the same from 02-06
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th 0.809
6th 0.630
Anybody with an 02-03 wanna trade me for my 05? I'd love to have to be able to cruise on the interstate at 400 less rpm.
Old Jan 31, 2011 | 10:17 AM
NmexMAX's Avatar
dot dot dot ...
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th 0.809
6th 0.630
Keep in mind the tire size (OEM) changed from 03-04, so the difference might lie in there.
Old Jan 31, 2011 | 12:47 PM
jasoneon's Avatar
Those are the gear ratios inside the transmission. I think the tires got bigger in 04, right? If so, then 04's and up would run lower rpm if given the same final drive ratio.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
