Temperature gauge flickers between correct display and displaying zero (cold)
Old Jul 22, 2011 | 10:44 AM
88FordFestiva's Avatar
So my temperature gauge flickers. It changes up to a few times per second between displaying the correct temperature, and displaying fully-cold.
My mechanic said that to fix it he would need to replace the whole cluster. I would like to know from you guys if there is any way I can fix this myself.
Old Jul 24, 2011 | 12:54 PM
1hawaii50's Avatar
Depends if it is the sender, or the gauge itself. Do you have anybody near you that can swap clusters with you? If you swap clusters and it still acts up, then it's not in the cluster.
Old Jul 25, 2011 | 06:40 AM
njmaxseltd's Avatar
Why don't you start by checking the connection at the sensor before you swap clusters?
Old Jul 25, 2011 | 10:01 AM
asand1's Avatar
I, m on my Phoenix right now(at work), but I posted in a recent thread with a link to a fix for this. The spade terminal on the sensor is probably loose. If so, you can clean and folder it without removing the Senor for a free fix. Its located on the driver side of the front head. What's happening is it drops from the correct ohms to infinity when it wiggles.
Old Jul 25, 2011 | 10:06 AM
asand1's Avatar
BTW, unless he's already diagnosed it to the cluster you mechanic is a hack or a cheat. Don't go back to him. It could also be a loose connection on the back of the cluster. 99% of the time with gauges, its a sensor.
Old Jul 25, 2011 | 10:10 AM
asand1's Avatar
Not sure what year yours is. The thread I'm referring to is in 4th Gen.
Old Jul 25, 2011 | 10:11 AM
Geo717's Avatar
I just had the a very similar problem ,it was the temp sensor in the front of the car.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
wiseguy6199
18
Oct 1, 2015 12:28 AM
leatherneck
Sep 30, 2015 09:16 PM
