View Poll Results: Which One Should I take care of in my next paycheck?
ATF
10.00%
Radiator
30.00%
Side Motor Mounts
0%
Front Tires
30.00%
Rear Shocks
20.00%
Rear Brakes
10.00%
Voters: 10. You may not vote on this poll
I need help Making some decisions.
Old Sep 18, 2011 | 10:30 AM
Shift_A32B's Avatar
Well I am happy to say my max has 214k miles with no oil leaks or CEL. There are some couple of things I want to change before I am completely done putting money on my max and just drive it until the engine gives out. Of course I take care of my max and drive it like a grandma; most of the times. I change the oil every 3k-4k miles. These are the things I've changed:
NGK Spark Plugs,
Both wheel bearings
Front Disks and brake pads
Front Full Assembly Struts/springs (Monroe)
Front and Rear Motor Mounts
o2 sensors
Valve Cover Gasket.
IM Gasket.
Driver side half-shaft.
Cleaned out IM, TB, EGR, IACV; new gaskets for each
PCV Valve
Hood Struts
Outer Tie Rod Ends
Stillen Y-Pipe
Changed OEM Filter to CAI
Knock Sensor.
That's all I can recall.
Well here are the things I to change but unfortunately I don't have a lot of money to change everything at the same time.
1. ATF: Flushed and refilled once since I got my max...not long ago...my trans slips.
2. There is some dry coolant on top of the radiator, some the upper hose some dry coolant as well. I don't have to add coolant/water every week or month. Last time I added was like 2-3months ago. I am planning to get an aluminum radiator.
3. Recently changed the front and rear mounts, they were completely shot. Felt the difference with the new ones. I went OEM. Now, upon hard acceleration, there is still some rattling. I know my side mounts are not in good condition.
4. Tires have very low thread. maybe 20-30%.
5. Rear shocks: My car bounces a lot from the back, boots look like sliced pepperoni. I am planning to lower my car, so I am just planning to get just the spring for the front and struts/springs for the rear.
6. Rear brake pads looks low already.
Now which one do you think is a must in my next paycheck?
Old Sep 18, 2011 | 10:46 AM
Tires.
Old Sep 18, 2011 | 11:13 AM
Shift_A32B's Avatar
Tires.
If I change my tires, I'll have enough for ATF
Old Sep 19, 2011 | 07:35 AM
Dave H.'s Avatar
I didn't vote, but I'd go with brakes and tires first. Seems like a safety issue. Then shocks for the rear.
Old Sep 19, 2011 | 08:39 PM
CenTexSS's Avatar
Tires for sure
Old Sep 19, 2011 | 09:49 PM
MrChaos10711's Avatar
Tires
Old Sep 19, 2011 | 10:30 PM
Bassman.357's Avatar
tires, then rear pads, then ATF
its not that hard to flush an automatic trans, just time-consuming, me and my father flushed a sealed automatic trans system on my brothers 98' dodge dakota, it took 3 hrs but...it def. worked and was hella cheap
Old Sep 20, 2011 | 10:58 AM
datboired832's Avatar
true
Old Sep 21, 2011 | 09:15 AM
Shift_A32B's Avatar
Thanks everyone for your input. For sure I'm getting tires for the front first. Rear tires are in good condition...I just don't want to move them to the front, I am still paranoid from the last time I lost control...
Old Sep 24, 2011 | 12:21 PM
DennisMik's Avatar
Depends on how long between this current question and when the next time you can afford something. Rear tires and brakes take a long time to wear out. I think the next round is between the shocks and the atf change.
The radiator is a real question mark and maybe it should be next the more I think about. On my 97, I went almost a year with the radiator seeping before I decided to change it. On my 2000, it was only a week from when I first saw seepage to when it blew its guts out.
Old Sep 24, 2011 | 01:05 PM
Nexus67's Avatar
Tires. 20% thread is no good.
Old Sep 24, 2011 | 03:00 PM
Shift_A32B's Avatar
Tires is my first priority right now. I bought the lower control arms and front sway bar end links kit and ES bushings. I also bought the ATF D-Matic from Nissan. I will get the tires once all of this is done, which will be next weekend. Rear brakes and radiator will be next, after will be the rear shocks, leaving the mounts for last.
Old Sep 28, 2011 | 01:13 PM
maxima2500's Avatar
upgrading tires make sense
Old Sep 28, 2011 | 01:21 PM
Shift_A32B's Avatar
My Cv axles started clicking today when I turn. I am getting the axles today as well. Its going to be a big suspension make-over this weekend.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
05RLS2
Sep 27, 2015 09:24 PM
